| New Reply |
energy in E=mc2 |
Share Thread | Thread Tools |
| Jun24-12, 07:51 AM | #35 |
energy in E=mc2I wonder how this translates to more realistic scenarios where there are no truly inertial frames. More specifically, shouldn't the equation E=mc2 even though derived from SR, really be more of a GR formula? I guess it can't be given that neither mass nor energy are well defined in GR. But the situation is a bit paradoxical: invariant mass and energy are well defined within SR and therefore E=mc2 considered an SR formula, but at the same time in more physical terms we accept the equivalence of inertial and gravitational mass and therefore strictly speaking mass is outside the range of SR in as much as gravitation cannot be explained within SR. |
| Jun25-12, 02:21 AM | #36 |
What is rest mass? As Naty1 pointed out, rest mass includes numerous energy components, both kinetic and potential. 1Kg of uranium consists of the rest mass of quarks, qluon field energy, atomic binding energy, thermal kinetic energy etc. All of these mass-energy components make up its 1Kg rest mass. Now it seems odd to me that if I now set this complex 1Kg package of mass-energy in motion, that I am obligated to record the increase in energy in Joules, not Kg, because it happens to be motion. And, yet, if I place this moving 1Kg into a larger, stationary, container, its kinetic energy is now allowed to be converted to Kg and counts toward rest mass of the larger container. I know that teaching relativistic mass has gone out of favor, and for some valid reasons, but I think that there is an unintended consequence. Students should not get the impression that mass and energy are fundamentally different things or that e=mc^2 is a rule that tells how much of one can be converted to the other. Energy can neither be created nor destroyed, and energy, in all of its forms, has mass. Mass also can neither be created nor destroyed, and in all of its forms, has energy. Mass and energy are two names for the same thing, and neither one is changed nor transformed into the other. Rather than mass being changed into energy, the view of special relativity is that rest mass has been changed to a more mobile form of mass, but remains mass. In the transformation process, neither the amount of mass nor the amount of energy changes, since both are properties which are connected to each other via a simple constant. |
| Jun25-12, 02:37 AM | #37 |
| Jun25-12, 12:22 PM | #38 |
| Jun26-12, 03:41 AM | #39 |
*"The mass of a body is a measure of its energy-content"
| Jun26-12, 11:30 AM | #40 |
| Jun27-12, 02:38 AM | #41 |
http://www.abc.net.au/science/articl...15/1872353.htm |
| Jun27-12, 11:09 AM | #42 |
| Jun28-12, 07:14 AM | #43 |
gαβ Pα Pβ = m2 c2 where Pα is the 4-momentum, which is defined in GR, as well as SR. |
| Jun28-12, 07:35 AM | #44 |
![]() As a photon has no rest mass (it's an impossibility!), I assumed that you meant the mass of a system in which the box is in rest - which is also the time-averaged rest mass of the system if the box has perfect mirrors. Compare: - http://www.weburbia.com/physics/light_mass.html - http://math.ucr.edu/home/baez/physic...y/SR/mass.html (note: I was slightly involved with that) It's conceptually similar to a box with loss-less bouncing tennis balls inside: the time-averaged "rest mass" of the system is the sum of E/c2 of the parts. |
| Jun28-12, 11:16 AM | #45 |
| Jun28-12, 03:13 PM | #46 |
| Jun28-12, 04:02 PM | #47 |
| Jun29-12, 02:24 AM | #48 |
| Jun29-12, 07:44 AM | #49 |
| New Reply |
| Thread Tools | |
Similar Threads for: energy in E=mc2
| Kinetic Energy, Conservation of Energy, Potential Energy, etc | Introductory Physics Homework | 6 | ||
| Work-Energy Theorum: Spring potential energy vs Kinetic Energy | Introductory Physics Homework | 4 | ||
| cosmological constant or dark energy or vaccum denisty/energy/energy density | Astrophysics | 9 | ||
| solar energy heat energy light energy...... | Engineering Systems & Design | 2 | ||
| [SOLVED] Mechanical Energy vs Potential Energy & Kinetic Energy | Introductory Physics Homework | 3 | ||
