| New Reply |
Existent solution to the linear system Ax=b |
Share Thread | Thread Tools |
| Jun21-12, 04:38 PM | #1 |
Suppose that the linear system Ax=b is given for some symmetric A, and it is known that vector c spans the null-space of A.
How could one formally show that if b is not orthogonal to c, the solution to the system Ax=b does not exist? To remind you, the null-space of A contains all vectors u for which Au=0. |
| Jun21-12, 04:51 PM | #2 |
Think about
[tex](Ax)^T c[/tex] where x is an arbitrary vector and c spans the null-space. |
| Jun22-12, 03:07 AM | #3 |
That would imply x^T Ac=x0=0. How do you relate this to the above problem?
| Jun22-12, 03:30 AM | #4 |
Existent solution to the linear system Ax=bI'm assuming A is nxn (since you said it is symmetric). From this if c spans the null-space it must be an n-dimensional column vector. From this you can use the decomposition argument that a basis can be broken into something and its perpendicular element (some books write it as v_perp + v = basis). Your zero vector c is perpendicular to b if you wish to have full rank. If this is not the case, then you can show that you don't have full rank and that a solution should not exist. For specifics you should look at rank nullity, and for the v_perp + v = basis thingy, this is just a result of core linear algebra with spanning, dimension, and orthogonality. |
| Jun22-12, 04:46 AM | #5 |
| New Reply |
| Thread Tools | |
Similar Threads for: Existent solution to the linear system Ax=b
| Introducing Rigor to my existent knowledge (Calculus and Linear Algebra) | Science Textbook Discussion | 2 | ||
| general solution of linear system | Calculus & Beyond Homework | 4 | ||
| Linear algebra: Finding a linear system with a subspace as solution set | Calculus & Beyond Homework | 1 | ||
| Condition # and Linear System Solution | Linear & Abstract Algebra | 0 | ||
| Solution to system of linear equations in range of system matrix | Calculus & Beyond Homework | 2 | ||
