How was the irrationality of pi proven?
  • Context: Undergrad
  • Thread starter Thread starter Nerditude
    Irrational Pi
The discussion centers on the proof of the irrationality of pi, exploring its implications and the nature of pi as both irrational and transcendental. Participants delve into the definitions and properties of pi, as well as the mathematical theorems related to its irrationality.
  • One participant questions the implications of pi being irrational in relation to its definition as the ratio of a circle's circumference to its diameter.
  • Another participant notes that pi is transcendental, meaning it is not a solution to any polynomial equation with rational coefficients, contrasting it with the Golden ratio.
  • A participant references a theorem related to proving irrationality, suggesting that if certain conditions are met, a positive real number can be shown to be irrational, though the proof is described as elementary but lengthy.
  • Some participants express interest in finding proofs or further discussions on the topic, including links to external resources and previous threads on the forum.
Participants express various viewpoints on the nature of pi and its proof of irrationality, but there is no consensus on a specific proof or the implications of pi's properties. The discussion remains unresolved regarding the best approach to proving pi's irrationality.
Participants reference the need for specific mathematical theorems and proofs, indicating that the discussion may depend on understanding complex mathematical concepts and definitions related to irrationality and transcendental numbers.
Nerditude
Here's a question. Pi is said to be the ratio of a circle's circumference to its diameter. If this is the case, what does it say about the circumference of a circle that pi is still irrational.
I get that pi is also used in the calculation of a circumference in the first place. Since this is true, it has to be the case that pi has been proven to be irrational independently of its definition.
So, the question is, how did we prove pi is irrational?
Nothing I can tell you that a quick Google search won't tell you. But one thing you might want to be aware of is that pi is also transcendental, meaning that it is the solution to no polynomial equation, or more precisely, "that is not algebraic—that is, it is not a root of a non-constant polynomial equation with rational coefficients." See: http://en.wikipedia.org/wiki/Transcendental_number
This, in contrast, for instance, to the Golden ratio, which is irrational, but not transcendental.
Incidentally, here is a link to another thread on this forum where the same issue was discussed at some length:
Looking for "Easy" proof of Pi Irrational
https://www.physicsforums.com/showthread.php?t=8193
As for the below question...
It's kind of mind-bending, but if you were to snip a perfect circle and stretch it out into a straight line along an x-axis demarcated into measurement increments as small as you please, then, while that line it would be "this long" and no longer, or "this short" and no shorter, well, good luck being able to locate, or rather, specify, where exactly the endpoint of that line is relative to your 0 point.
Halls of Ivy mentioned the following theorem in the above linked thread...
Of course, that requires that one know the theorem:
Let c be a positive real number. If there exist a function, f, positive on the open interval from 0 to c, continuous on the closed interval from 0 to c, and such that all its anti-derivatives can be taken to be integer valued at 0 and c (by appropriate choice of the "constant of integration") then c is irrational.
The proof of that is elementary but long.
Does anyone know where I might find a proof? That seems like a wonderful theorem.
  • · Replies 28 ·
  • · Replies 26 ·
  • · Replies 36 ·
  • · Replies 54 ·
12K
9K
  • · Replies 54 ·
17K
