A simple calculation that got me stumped.
  • Context: Undergrad
  • Thread starter Thread starter MathematicalPhysicist
    Calculation
The discussion revolves around calculating the area defined by the equation \(y^2 + z^2 = 2ax\) with specific limits for \(x\). Participants explore different approaches to set up the integral and express the variables involved, while grappling with the limits of integration and the use of polar coordinates.
  • One participant proposes using the coordinates \(y = \sqrt{2as}\cos(t)\), \(z = \sqrt{2as}\sin(t)\), and \(x = s\) but struggles with determining the limits of integration.
  • Another participant rewrites the equation as \(x^2 + y^2 = 2az\) and expresses \(y\) as a function of \(x\), suggesting limits for the integral.
  • A third participant discusses inequalities derived from the equations, indicating that \(s\) must be greater than or equal to \(a\) and explores the implications for \(t\).
  • One participant expresses confusion regarding the previous solutions and indicates a potential misunderstanding of the problem.
  • Another participant acknowledges a mistake in their earlier reasoning and questions the meaning of the limits in the integral proposed by others.
  • A later reply suggests using polar coordinates for integration, providing a detailed expression for the radius and discussing the need to adjust the limits based on the original problem constraints.
Participants express differing views on the correct approach to the problem, with no consensus reached on the best method for setting up the integral or the limits of integration.
Some participants note potential misunderstandings or missing elements in the problem statement, which may affect their calculations and interpretations.
I need to grade some work, and there's an integral to calcaulte:
compute the area of y^2+z^2=2ax where x is between a and y^2/a.
I tried using the coordinates:
[itex]y=\sqrt{2as}\cos(t) \ z=\sqrt{2as}\sin(t) \ x=s[/itex]
But I don't see how to find the limits of integration with respect to s and t.
Thanks.
The higher you get in maths, the less you remember what you learned in earlier years. :-(
I rewrite it as [itex]x^2+y^2=2az[/itex] where z is between a and [itex]x^2/a[/itex]. I just renamed the variables: y as x, z as y and x as z (I am more comfortable that way.)
Written explicitly as a function of x, y is [itex]y=\sqrt{2az-x^2}[/itex]. We know the limits, and hence this integral becomes
[tex]\int_{a}^{x^2/a}\sqrt{2az-x^2}dx[/tex]
I think you can go on from there.
solving your own equations says that a ≤ s = x ≤ y^2/a = 2s cos^2(t). That gives s ≥ a.
Then canceling s, from s ≤ 2s cos^2(t), we have
1 ≤ 2cos^2(t), so cos^2(t) ≥ 1/2, so -π/4 ≤ t ≤ π/4.if that open ended inequality for s bothers you, note that your surface is unbounded in the x direction.
I.e. for any x ≥ a >0, it is easy to solve for y such that 2ax ≥ y^2 ≥ ax, and then since 2ax - y^2 ≥ 0,
one can also solve for z such that z^2 = 2ax - y^2, or z^2 + y^2 = 2ax.
Same with me. Your solution puzzles me. I think there is something I am missing in the question.
I changed a mistake in mine. (I canceled s/s and got 0.)
in your integral what does it mean to let x range from a to x^2/a?
Hi MP,
How about this; if [itex]x[/itex] was from 0 to [itex]\frac{y^2}{a}[/itex] then we could use polar coordinates to integrate using the radius value based on θ, so using Pythagoras we have that [itex]cos θ = \frac{y^2}{2ay^{\frac{2}{a}}}[/itex] and therefore [itex]y = (2a\cosθ) ^{\frac{1}{2-\frac{2}{a}}}[/itex] so the squared radius will be
[tex]r(θ)^2 = 2a((2a\cosθ) ^{\frac{1}{2-\frac{2}{a}}})^{\frac{2}{a}}[/tex]
Now we simply polar integrate it from 0 to 2π [itex]\frac{1}{2}\int_0^{2π} r(θ)^2 dθ[/itex] but since [itex]x[/itex] is not from 0 to [itex]\frac{y^2}{a}[/itex] but from [itex]a[/itex] to [itex]\frac{y^2}{a}[/itex] we need to take away that part, so finally we have:
[tex]\frac{1}{2}\int_0^{2π} r(θ)^2 dθ - \frac{1}{2}\int_0^{2π}\min( r(θ)^2 , 2a^2) dθ[/tex]
I didn't thoroughly check it but I think you get the idea.
