Geodesic on a cone, calculus of variations
The discussion focuses on finding geodesics over a cone using cylindrical coordinates, specifically defining the coordinates as x=r cos(θ), y=r sin(θ), and z=Ar. The arc length is derived as ds=∫(r1 to r2)√(1+A²+r²(dθ/dr)²)dr, and the Euler-Lagrange equation is applied to derive a non-linear differential equation. The participants confirm the approach and explore the separability of the equation, ultimately validating the method while noting alternative spherical coordinates could also be used.
  • Understanding of cylindrical coordinates in calculus
  • Familiarity with the Euler-Lagrange equation
  • Knowledge of differential equations, particularly non-linear types
  • Basic concepts of geodesics in differential geometry
  • Study the application of the Euler-Lagrange equation in different coordinate systems
  • Explore the derivation of geodesics in spherical coordinates
  • Investigate non-linear differential equations and their solutions
  • Learn about the implications of geodesics in the context of differential geometry
Mathematicians, physicists, and students studying calculus of variations, differential geometry, and those interested in the geometric properties of surfaces.
Telemachus
I have to find the geodesics over a cone. I've used cylindrical coordinates. So, I've defined:
[tex]x=r \cos\theta[/tex]
[tex]y=r \sin \theta[/tex]
[tex]z=Ar[/tex]
Then I've defined the arc lenght:
[tex] ds^2=dr^2+r^2d\theta^2+A^2dr^2[/tex]
So, the arclenght:
[tex]ds=\int_{r_1}^{r_2}\sqrt { 1+A^2+r^2 \left ( \frac{d\theta}{dr}\right )^2 }dr[/tex]
And using Euler-Lagrange equation:
[tex]\frac{\partial f}{\partial \theta}=0[/tex]
[tex]\frac{\partial f}{\partial \dot \theta}=-\frac{r^2\frac{d\theta}{dr}}{\sqrt{1+A^2+r^2\left ( \frac{d\theta}{dr}\right )^2}}[/tex]
[tex]\frac{d}{dr}\frac{\partial f}{\partial \dot \theta}=0 \rightarrow \frac{\partial f}{\partial \dot \theta}=-\frac{r^2\frac{d\theta}{dr}}{\sqrt{1+A^2+r^2\left ( \frac{d\theta}{dr}\right )^2}}=K[/tex]
The differential equation which I've arrived is non linear. I don't know if what I've done is fine. I know the problem can also be done using spherical coordinates instead of cylindrical, but I've choossen to do it this way.
[tex]z=Ar[/tex]
So, the arclenght:
Is it separable? I didn't simplify your expression, but it looks like you might have
[itex]d\theta=g(r)dr[/itex]
Yes, you're right:
[tex]r^2\frac{d\theta}{dr}=K \sqrt{ 1+A^2+r^2\left ( \frac{d\theta}{dr}\right )^2 }[/tex]
[tex]r^4 \left ( \frac{d\theta}{dr} \right )^2=\gamma \left [ 1+A^2+r^2\left ( \frac{d\theta}{dr}\right )^2 \right ][/tex]
[tex]r^4 \left ( \frac{d\theta}{dr} \right )^2=\gamma \left [ 1+A^2+r^2\left ( \frac{d \theta}{dr}\right )^2 \right ][/tex]
[tex](r^4-r^2\gamma) \left ( \frac{d\theta}{dr} \right )^2=\gamma \left [ 1+A^2 \right ][/tex]
[tex]d\theta=\sqrt{ \frac { \eta }{r^2(r^2-\gamma) }}dr[/tex]
eta and gamma are constants.
Anyway, I wanted to know if what I did was ok. I don't care that much about the integral :P
Thank you algebrat.
