Force Components: Horizontal & Vertical Effects
  • Thread starter Thread starter alcatras
    Components Force
The discussion focuses on the components of force exerted by water on container walls, specifically addressing how these components change with sloping walls. When considering the entire container, the vertical force component remains consistent regardless of wall orientation. However, when analyzing just the side walls, the pressure exerted by the liquid acts normal to the sloped surface, necessitating the use of trigonometric functions to resolve the force components relative to the chosen coordinate system.
  • Understanding of basic physics concepts related to force and pressure
  • Familiarity with trigonometric functions for resolving force components
  • Knowledge of coordinate systems in physics
  • Basic principles of fluid mechanics
  • Study the principles of fluid statics and pressure distribution in containers
  • Learn how to apply trigonometric functions to resolve forces in inclined planes
  • Explore the concept of resultant forces in different coordinate systems
  • Investigate the effects of sloping surfaces on pressure exerted by fluids
Students and professionals in physics, engineering, and fluid mechanics who are looking to deepen their understanding of force components in various geometrical configurations.
alcatras
Hi. I'm a newb here. I've got a problem about components of force. Water applies force to the walls of container as it does to the bottom. It has only horizontal compenent when the container is straight (walls parallel) but what about in containers with inward and outward sloping walls? In which one vertical component points down? Can anyone explain or give a hint plese?
:smile: :smile: :smile:
Thanks
You are not clear what your problem is.
The resultant force depends on what your system boundary is. If you take the whole container wall (bottom and sides) there will be a vertical component pointing downward of the same value, whether they are vertical or sloping.
If you take just the side walls of the container, then there will be a vertical force component pointing downward.
The liquid is going to exert a pressure that is normal to the sloped surface. If you coordinate system does not correspond to that slope, you will have to break that force into it's components using basic trig. Everything will be relative to the coordinate system you specify.
  • · Replies 21 ·
