New Reply
what is the value of e^-j(infinity)
Share Thread Thread Tools
Jun25-12, 03:16 AM   #18
When taking the limit as x -> infinity, i was talking about applying it to the part with polynomial expansion, not the the cosx -jsinx
∞ - i∞
can someone explain why this isn't an indeterminate form?
i know ∞ isn't a fixed number, it represents a very large quantity, and if you scale that very large quantity by a finite quantity you still get an infinite quantity
so i think you can treat ∞ - i∞ as ∞ - ∞
Jun25-12, 04:53 AM   #19
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by cocopops12 View Post
∞ - i∞
It's not indeterminate. It is undefined. You could give several (non-equivalent) meaningful definitions to it though.
NO!!!!! Infinity is not a number, it is not a very large quantity. Infinity is a symbol that behaves in a certain way.
First you got to define what these two expressions even mean.
Jun25-12, 05:56 AM   #20
Recognitions:
Homework Helper Homework Help
Why are you even bringing this up? The question in the OP was about [tex]\lim_{x\to\infty}e^{-ix}[/tex] which is equivalent to [tex]\lim_{x\to\infty}\left(\cos(x)-i\sin(x)\right)[/tex][tex]=\lim_{x\to\infty}\cos(x)-i\lim_{x\to\infty}\sin(x)[/tex]
cos and sin fluctuate between -1 and 1, so the point you're trying to make about what [itex]\infty-i\infty[/itex] is both irrelevant and futile.
Jun25-12, 08:30 AM   #21
Quote by micromass View Post
Your reasoning is probably
[tex]\lim_{x\rightarrow 0} \frac{x}{x}=\frac{\lim_{x\rightarrow 0} x}{\lim_{x\rightarrow 0} x}[/tex]
But this is not allowed. It is only allowed if the two limits exists (which is the case here) and if the denominator is not 0 (which is not the case).
My reasoning isn't even remotely related to that. I am saying that the given limit (in a precise sense) can equal 0 - this does not mean that it is. However, if we were obliged to assign a specific value to this limit, it would most righteously be 0.
I will explain this further because I think there might be gaps left. The divergence of the series 1+1+1+1+1... is obvious. However, if one was to assign a value to this sum, one can use zeta function regularization to land on the value -1/2, and this value is employed in physics with several applications.
Jun25-12, 08:35 AM   #22
Recognitions:
Quote by Millennial View Post
I have no idea what you mean. How can a given limit equal 0 if it is not 0??
This is a completely different topic. I don't see what that has to do with the previous discussion??
Jun25-12, 11:54 PM   #23
Let's expand eiy
eiy= 1 + iy + (iy)2/2! + (iy)3/3!+ ...
As you can clearly see if y→-∞ then we would clearly have the above expression equate to
1 + 0 + 0 ...
and hence the limit should become 1 if you find out the answer using the above expansion.
Jun25-12, 11:57 PM   #24
Recognitions:
Quote by iVenky View Post
Let's expand eiy
1 + 0 + 0 ...
How would that be "clearly" true?? I don't see it.
Jun26-12, 12:01 AM   #25
Recognitions:
1 + 0 + 0 ...
Are you confusing y with ey?
Jun26-12, 12:21 AM   #26
Let's expand eiy
1 + 0 + 0 ...
But the forth term is ##\frac{(iy)^4}{4!}##. Then as y→-∞...
Jun26-12, 09:50 AM   #27
Sorry guys. I have actually confused y with ey
New Reply
Tags
complex functions
Thread Tools
Similar Threads for: what is the value of e^-j(infinity)
Thread Forum Replies
Integrating sinc(x)^4 between negative infinity to infinity using complex analysis Calculus & Beyond Homework 6
A Definite integral where solution. involves infinity - infinity Calculus & Beyond Homework 8
A Definite integral where solution. involves infinity - infinity Calculus & Beyond Homework 3
Integral of a delta function from -infinity to 0 or 0 to +infinity Quantum Physics 31
