Revisiting an old problem with startling new mathematical results
  • Context: Undergrad
  • Thread starter Thread starter manuelsmarin
    Mathematical
The discussion centers around a paper claiming to provide a new proof of Fermat's Last Theorem using high school algebra. Participants engage with the validity of the arguments presented, the use of mathematical logic, and the implications of setting certain variables equal to one another.
  • One participant claims to have proved Fermat's Last Theorem, suggesting that the proof is straightforward and based on high school algebra.
  • Another participant questions the validity of setting variables equal, specifically challenging the assumption that f can equal d in all cases.
  • Concerns are raised about the mathematical logic used in the proof, particularly regarding the transformation of equalities into inequalities.
  • Some participants argue that the original poster's understanding of mathematical principles and communication is lacking.
  • There is a challenge to the original poster to submit their proof to a journal for peer review rather than seeking validation in the forum.
  • Participants express frustration over the original poster's refusal to acknowledge critiques and corrections regarding their arguments.
Participants generally disagree on the validity of the proof presented. Multiple competing views remain regarding the mathematical arguments and the assumptions made about variable equality.
There are unresolved issues regarding the assumptions made in the proof, particularly the conditions under which variables can be set equal. The discussion also highlights potential misunderstandings of mathematical logic and the requirements for formal mathematical writing.
Choose your own question
  • Do we actually use equality testing, if only partially, when solving equations?
    Votes: 0 0.0%
  • "definitional loops," are they fixed with polynomial equations and their solutions?
    Votes: 0 0.0%
  • The math is simple. Where is the fallacy?
    Votes: 0 0.0%
  • Total voters
manuelsmarin
I've got the attached paper... It's interesting, because it deal with an old complex problem is a seemingly simple form, and just using high school algebra. Check it out!
Here is the attackment:
You seem to like to set f=d. Why can you do that? Certainly f is not equal to d in general.
You seem to believe that very trivial, old-known results are new (like that "never before known axiom or postulate", as you called it)...
I'm not even sure what you think you've proved: is is true that you believe that you've proved Fermat's Last Theorem in that paper of yours? Because if you do then, with all due respect, you're dead wrong.
I think you need to begin taking some basic mathematics courses, at least to know how to write mathematics and/or how to use logic, and then perhaps go back to your paper and, if you still think it is worthwhile, re-write it all through.
DonAntonio
DonAntonio... you took too many words to reply to this. And yes, I proved the Theorem... as simple as that. Just follow the arguments and don't get excited about nothing. This is not religion or politics. Exactly where is my arguments wrong?
why should we do your work for you? if you have a proof of fermat, submit it to a journal and the editor will try to find a referee willing to read it.
I showed you were it is wrong. If you're not going to reply to our comments, then this will be locked.
Statements such as
By making a = b we transformed a perfectly good equality, [2], into an inequality, [2’].
when you clearly wrote ##b = (b^2 – d^2) / 2d## the line before are not valid in mathematics. If you write an equality it is an equality. You are not allowed to retrospectively change it. As Don said, you clearly do not understand mathematical logic or the requirements of writing a paper.
Just what I thought...but you know what? Sometimes things are SO wrong that it isn't easy to point out where "exactly" they are wong. I can tell you where you begin to go astray from logic, and mathematics, which is pretty close to the beginning, but I don't think that will do any good to anyone.
As already said, it is obvious you're not a mathematician as it is obvious you don abide neither by its logical rules nor by the standard ways to communicate mathematical ideas, so again: I think the best for you is to begin studying some basic maths and THEN, after you already know some, go back to your paper and check whether it is worthwhile to keep it as it is, to improve it, to change it...or to toss it away.
DonAntonio
I had this before:
b = (a^2 - d^2) / 2d is an equality. Once I changed it to b = (b^2 - d^2) /2d I turned it into an inequality means that b ≠ (b^2 - d^2) /2d, even though the quadratic equation
b^2 - 2db - d^2 = 0 has a solution that is irrational... and here I'm talking about rational solutions.
Why can you set f=d??
Another thing... try the formulas. If they work, I'm doing correct math. If they don't, I'm all yours to lapidate. But don't get stuck in minucia. I'm no Newton, but if he had followed the suggestions and objections of Bishop Berkeley, we've probably have no Calculus today, if in addition, no one had understood Mr. Leibnitz own nomenclature.
micromass... because f can actually be equal to d. Try this 3^2 + 4^2 = 5^2, and a = b -1 = 4 -1 =3, while c = b + 1 = 4 +1 = 5, which means tha f = d =1.
But micromass's point is that you have not proved the case ##f\neq d##.
OK, this proves you have no idea how math works. If you want your mistake, there it is. f does not have to equal d.
Thread locked. Do not post this again.
10K
  • · Replies 25 ·
