Very small particles induce other particles
  • Context: Graduate
  • Thread starter Thread starter Sterj
    Particles
This discussion centers on a thought experiment proposing that very small particles, specifically those near Planck-length, can induce the formation of larger particles. The concept suggests that smaller particles, when in a special state, can influence each other's movement, leading to the motion of a larger particle. The theory aligns with the Phi-Wave Aether theory, which posits that wave centers emit and absorb waves at specific frequencies, forming larger particles through resonance. Key questions raised include the specifics of particle induction, the conditions under which this occurs, and the implications of particle movement direction.
  • Understanding of elementary particle physics
  • Familiarity with Planck-length and its significance in quantum mechanics
  • Knowledge of wave-particle duality and resonance phenomena
  • Basic principles of theoretical physics and model formulation
  • Explore the implications of Planck-length in quantum field theory
  • Research the Phi-Wave Aether theory and its applications
  • Study the principles of particle induction and resonance in physics
  • Investigate existing models that explain particle interactions and formations
Physicists, theoretical researchers, and students interested in particle physics and the foundational concepts of quantum mechanics will benefit from this discussion.
Sterj
Yesterday I made a Thought experiment about elementary particles (electron).
The physicists might have another oppinion. (Say if it can't be like this):
"Very small particles (near Planck-length) with a very small mass induces a bigger particle. for example: very small particle A1, A2, ..., An gives a larger particle P. The smaller particles are in a special state. If particle A1 moves in direction S then particle A2 moves also in S (to say it easy). And if A1 moves and A2 and An, then also P moves in same direction."
Can that "theorie" be possible? And if yes, does this theory already exists?
This sounds a bit like my Phi-Wave Aether theory [http://freespace.virgin.net/ch.thompson1/Essays/PWA.htm]. The smallest "particles" are pulsating "wave centres", emitting waves at a standard frequency and absorbing them most efficiently when at the same frequency and in phase. Groups of wave centres will form larger particles when they are resonating, which will be when they are at single wavelength separations (or maybe half wavelength, or multiples thereof).
In my theory I go a little bit further and suggest that, because new wave centres are formed only when the intensity of the waves exceeds some threshold and because this is most likely to occur near existing wave centres, this is where new ones are most likely to be formed.
Caroline
I have a couple of comments on the original post:
1. You need to be more specific regarding how your model works. When you say that small particles "induce" a bigger one, do you mean that the new one is produced in addition to the smaller ones, or that at some point there is only the "induced" particle, whereas the small particles exist no loger? Similarly: what happens when the particles do NOT move in the same direction? how do their speeds affect the speed of the induced particle? And, you say that the smaller particles are "in a special state". Why do you need to specify that? in what sense is that state "special"? how is it different to the state of the other particles?
2. A different kind of question: what is the motivation for your theory? theories in physics arise because of the need of a model in a situation where existing models don't produce correct predictions, or as a result of realising that a simpler principle (than those in existing theories) is enough to explain the same phenomena.
3. Why do the particles need to be "near Planck-length"?
  • · Replies 38 ·
  • · Replies 17 ·
  • · Replies 87 ·
9K
