| New Reply |
Why Doesn't Diatomaceous Earth Cut Humans? |
Share Thread | Thread Tools |
| Jun24-12, 02:34 PM | #1 |
Diatomaceous earth is a very fine white powder, used for insect control among other things. According to my research on the webernets, it works by "cutting up" the exoskeletons of insects, and drying them out resulting in death.
Because this substance works through mechanical means rather than chemical, it is completely harmless to humans, pets (except your Madagascar cockroach), and is even found in many foods that we eat. However, no amount of searching I do can find me an answer to the simple question: why doesn't it cut humans? The only answer that I get is that it is "too small." Huh? If I have a sharp knife, and I make it even smaller, it's only become sharper, thus more capable of cutting me. How is this substance able to cut insects but not humans? |
| Jun24-12, 09:10 PM | #2 |
I'm not completely sure why it's safe for internal use but I would deduce it's because, the alimentary tract between the mouth and stomach is protected by mucous, and, once in the stomach the DE, which is calcium carbonate, is quickly dissolved by stomach acids. |
| Jun24-12, 09:23 PM | #3 |
Yeah, I've considered the possibility that "cut" isn't necessarily used in a literal sense as we imagine it. That could be the explanation.
| Jun24-12, 10:40 PM | #4 |
I understood (though I may be wrong) that where it does its damage is in the breathing canals in an insect's abdomen. If the diatomaceous earth is just the right size, it will get jammed in there and wreak havoc.
If our alveoli have a different dimension - larger or smaller - then no jamming. |
| Jun24-12, 10:54 PM | #5 |
| Jun24-12, 11:18 PM | #6 |
| Jun24-12, 11:49 PM | #7 |
Mentor
I can't vouch for the accuracy, but here is information that seems correct.
http://www.ehow.com/how_5049476_use-...t-control.html |
| Jun25-12, 02:03 AM | #8 |
More information here, method of action starts on page 339:
http://www.ksre.ksu.edu/grsc_subi/Te...nert_Dusts.pdf Be careful with inhalation if the dust is based on silica crystals. |
| Jun25-12, 02:48 AM | #9 |
| Jul20-12, 01:22 PM | #10 |
Bumping this as I never got a totally clear answer.
| Jul20-12, 03:15 PM | #12 |
Their best bet is that DE absorbs the wax ( epicuticular lipid layers) from the insect's outer shell. That wax is holding their moisture in, so without it they dry up and that leads to their death. There are pictures of a bug there covered with dust that has soaked up it's wax: looks covered in white moss. |
| Jul20-12, 06:13 PM | #13 |
So it doesn't have anything to do with cutting or chipping away the exoskeleton, but simply dries them out?
That sounds like an acceptable answer, but if that's the case then it's odd that most sources describe DE to "cut" insects. |
| New Reply |
| Thread Tools | |
Similar Threads for: Why Doesn't Diatomaceous Earth Cut Humans?
| Why doesn't the moon fall on earth? | Classical Physics | 9 | ||
| Why doesn't the Earth collide with the Sun? | General Physics | 9 | ||
| How many humans have lived on Earth? | General Discussion | 75 | ||
| Why is the earth constantly rotating, but we as humans can never feel it? | Earth | 32 | ||
| Exactly Why doesn't the moon fall and strike the earth? | Introductory Physics Homework | 5 | ||
