How Do You Calculate Angular Acceleration in a Rotational Torque Problem?
  • Thread starter Thread starter hun_nomin
    Rotational Torque
The discussion revolves around calculating angular acceleration in a rotational torque problem involving a cylindrical spool and a hanging mass. The original poster presents a scenario where a string is unwound from a spool, prompting questions about angular acceleration and the role of tension in the system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss applying Newton's second law to both the hanging mass and the spool, exploring the relationship between linear and angular acceleration. There are inquiries about the moment of inertia and how to calculate tension in the string.
Some participants have provided guidance on the equations needed to solve for tension and angular acceleration. There is ongoing exploration of the calculations involved, with no explicit consensus reached on the correctness of the answers provided.
Participants note the importance of understanding the setup, including the direction of forces and the definitions of variables like moment of inertia. There is mention of confusion regarding the classification of the problem within the forum.
hun_nomin
Question:
A light string 4 m long is wrapped around a cylindrical spool with a radius of 0.075 m and a mass of .5 kg. A 5 kg mass is then attached to the free end of the string causing the string to unwind from the spool.
a) What is the angular accelerataion of the spool?
b) how fast will the spool be rotating after all of the string has unwound?
I got an answer of 2613.333 for (a), but my teacher claims the answer is wrong. I just want to solve this problem or else it's going to kill me...so if any of you know how, please reply. He said the tension must be solved first. but i have no idea. i though the time would be .9 but seems not.
hun_nomin said:
Question:
Let's say that the string hangs on the right side of the spool, ok ?
Suppose the y-axis is upward vertically. First we apply Newton's second law for the mass. The acceleration is negative since it moves downward:
5*a = 5*g - T and T is the tension in the string.
Then we apply the second law of Newton for the spool with rotational inertia denoted as I (you can look this up) and angular acceleration a' : Ia' = torque on spool
the torque coming from the string-force (tangential to the spool) is equal to -RT (- because the spool moves along with the clock and R is the radius of the spool).
now you know that tangential acceleration is connected to the angular acceleration via a = a' * R (a' < 0 because the spool moves clockwise and a also < 0)
Now we have that Ia' = -RT or Ia/R = -RT or a = -R²T/I
let's put this in the first equation for the mass
5 (-R²T/I) = 5 * g - T
calculate T from this equation
once you know T, you know a...
marlon
Thanks
Thanks...i'm going to go solve it now. And sorry for double topics...i didn't realize i was posting a high school problem in the college section so i decided to post it again. Sorry
What is I?
I'm not sure what I is... is it equal to 1/2(.5).075^2?
that is correct !
marlon
T
If i did it correctly i got a T of 1.96. Is that the right answer?
  • · Replies 35 ·
