Proof of Order of b is a Factor of the Order of a in Cyclic Groups
The discussion revolves around a proposition concerning cyclic groups, specifically the relationship between the orders of elements within such groups. The original poster attempts to prove that if G is a cyclic group generated by an element a, and b is another element of G, then the order of b is a factor of the order of a.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the implications of the Division Algorithm in the context of group orders, questioning the validity of specific steps in the proof. They discuss examples where the order of b does not align with the initial assumptions, particularly focusing on cases where k does not divide n.
The discussion is ongoing, with participants providing examples to illustrate their points and questioning the assumptions made in the original proof. Some participants suggest that the relationship between the orders of a and b may depend on whether k divides n or if they are coprime, indicating a productive exploration of the topic.
Participants are examining specific cases with varying values of n and k, considering the implications of their greatest common divisor (gcd) on the orders of the elements involved. There is an emphasis on understanding the conditions under which the order of b can be determined as a factor of the order of a.
jmjlt88
Proposition: If G= <a> and b ϵ G, then the order of b is a factor of the order of a.
Proof:
Let G be a group generated by a. That is, G=<a>. Let b ϵ G. Since G is cyclic, the element b can be written as some power of a. That is, b=ak for some integer k. Suppose the order of a is n. Hence, an=e. We wish to show that the order of b is a factor of n. First, we shall divide n by k using the Division Algorithm. That is,
(1) n=qk+r for some integer q and 0≤r<n.
Then, we have,
(2) e=an=aqk+r=aqkar=e.
From (2), we observe that an=aqkar. Multiplying on the right by a-r, we obtain,
(3) ana-r=aqk. Then, we have,
(4) an-r=aqk=e.
Since an-r=e and 0≤r<n, we must have that r=0. With r=0, from (4), we get,
(5) an=aqk=(ak)q=bq=e.
Hence, the order of b is q and by (5), n=qk. That is, q|n and we have that the order of b is a factor of the order of a.
QED
I'm not sure how you got line (4)... Why does [itex]a^{qk}=e[/itex] ? You end up concluding that the order of b is q by this reasoning, but here is a contradictory example.
Consider [itex]G=C_5[/itex], where [itex]b=a^2[/itex] as in your problem. Then n=5, k=2, so division algorithm gives us [itex]n=5=2\times 2 + 1 = 2k+1[/itex]. You would conclude that the order of b is q=2, but [itex]b^2=a^4\neq e[/itex].
Back to the problem. You're trying to prove that the order of b is a factor of n. Why did the above example go wrong? Because k doesn't divide n... Let's do some calculations. [itex]b=a^2[/itex], [itex]b^2=a^4[/itex], [itex]b^3=a^6=a[/itex] and so on... We loop around and get back to the identity at [itex]b^5=a^{10}=(a^5)^2=e^2=e[/itex]. So in fact, the order of b is 5.
How does this help us? Both b and a are of order 5, so in fact, we aren't cheating when we say that the cyclic group generated by b is the same as that generated by a. More suggestively, [itex]<b>=<a^1>[/itex]. In this example, we had n=5 and k=2. n and k are coprime, so their gcd is 1.
Another quick example. Let's say n=8 and k=2. So [itex]b=a^2[/itex], [itex]b^2=a^4[/itex], [itex]b^3=a^6[/itex], [b^4=a^8=e], so b is of order 4, and we have that [itex]<b>=<a^2>[/itex]. n=8 and k=2 are not coprime; their gcd is 2.
That's probably suggestive enough :P
Thank you Christoff!
I'll get back to you later with the revised solution. But, for now, let me make sure I understand it intuitively.
So, we let b=ak. Now, k can either divide n, the order of a, or n and k can be relatively prime. If they are relatively prime, then the order of b and the order of a are the same [...but how can I justify this statement?]. Or else, k divides n and a logical progression similar to the above may work. Do I have the right idea?
Indeed, if k divides n, then the division algorithm immediately gives you r=0, so your proof is fine. But there's another scenario that can come up. What if k doesn't divide n, but they are NOT coprime?
Let's try n=10 and k=8. So we are interested in the order of [itex]b=a^8[/itex]. Computing powers, we get [itex]b^2=a^{16}=a^6[/itex], [itex]b^3=a^{24}=a^4[/itex], [itex]b^4=a^{32}=a^2[/itex], [itex]b^5=a^{40}=(a^{10})^4=e^4=e[/itex]. So the order of b is 5.
Note that in computing the powers of b, we managed to get [itex]a^8,a^6,a^4,a^2[/itex]and [itex]e[/itex]. So in fact, we can write [itex]<b>=<a^2>[/itex] since taking powers up to the fifth of a^2 will get you all of these elements. Notice that gcd(8,10)=2, and further, that the order of b is 10/2=5.
I claim that if gcd(n,k)=d, then [itex]<b>=<a^d>[/itex], and that the order of b is n/d, which of course divides n (which you were supposed to prove).
To prove this, you will first need to prove the two-sided inclusion [itex]<b>=<a^d>[/itex]. Then show that n/d is the smallest positive integer with the property that [itex]b^j=e[/itex] for some integer j. This second statement is a bit trickier, so here's another way of going about it...
The order of b is EQUAL to the order of the cyclic subgroup generated by it (if you haven't seen this, prove it. It isn't too difficult). So the order of b will be the smallest integer j such that [itex](a^d)^ja^{dj}=e[/itex] (by the nice little equality <b>=<a^d>). But n is the smallest integer such that a^n=e. Remember that d=gcd{n,k)...
Got it?
