Will the 1018 steel bar bend problem
  • Thread starter Thread starter jrd29673
    Bend Steel
The discussion focuses on the bending problem of a 1018 steel bar under varying loads and lengths. The original configuration featured a 7.8" long bar with a load of 480 lbs, while the new configuration involves a 12" long bar with a load of 1460 lbs. Key calculations include a bending moment of 1082 ft*lbs, a yield tensile strength (YTS) of 63800 psi, and a yield strength of 53700 psi. The importance of the second moment of area, rather than the cross-sectional area, is emphasized for analyzing bending moments in beams.
  • Understanding of bending moments in structural engineering
  • Familiarity with material properties of 1018 steel
  • Knowledge of the second moment of area (area moment of inertia)
  • Basic principles of load distribution and support in beam theory
  • Research the calculation of the second moment of area for circular sections
  • Learn about safety factors in structural engineering design
  • Explore the effects of load distribution on beam deflection
  • Study the mechanical properties of 1018 steel in detail
Structural engineers, mechanical engineers, and students studying material mechanics who are involved in analyzing the bending behavior of steel beams under various loads.
jrd29673
I need some help determining if a bar with increased length and loads is going to bend. The original length and loads were 1018 steel, 1 3/8 dia, 7.8" long with 480 lbs at one end and being supported with bearings at 2 locations 4.68" and 7.8" away.
The new configuration is 1018 steel, 1 3/8 dia. 12" long with 1460 lbs at one end and being supported with bearing at 2 locations 8.9" and 12" away.
I took 1460 lbs * 8.9 inch to get a bending moment of 1082 ft*lbs
The YTS is 63800 psi and the yield strength is 53700 psi.
Do I take the cross section area of 1.484 inch ^2 and multiply the yield strength. Then add a safety factor?
13K
13K
10K
