AC/DC Switch Ratings for Motor Control: Which Rating to Use?
  • Thread starter Thread starter mdjensen22
    Ac/dc Switch
The discussion revolves around the appropriate switch ratings for controlling a motor powered by bridge-rectified mains voltage, specifically whether to use AC or DC ratings for switches in series with the motor. The scope includes technical considerations related to electrical ratings and motor control applications.
  • Technical explanation, Debate/contested
  • One participant questions whether to use AC or DC ratings for switches in a motor circuit powered by bridge-rectified mains voltage, noting that the absence of filtering capacitors may affect the choice.
  • Another participant suggests using AC ratings if the switch is intended for AC purposes and emphasizes the importance of overspecifying ratings for safety.
  • A different participant clarifies that if the switch is on the AC side of the bridge, AC ratings can be used, but if on the DC side, DC ratings should be applied, citing the motor's inductance and the bridge's behavior as factors in the decision.
  • One participant expresses appreciation for the insights shared in the discussion.
  • A later reply acknowledges the compliment and wishes success for the project.
Participants present differing views on the application of switch ratings, with no consensus reached on the best approach for determining the appropriate ratings based on the switch's position in the circuit.
Participants discuss the implications of inductance and the behavior of the bridge rectifier, but there are unresolved assumptions regarding the specific conditions under which AC or DC ratings should be applied.
mdjensen22
I have a motor that is running off bridge-rectified mains voltage. There are no filtering capacitors across the rectifier output.
When figuring the ratings needed for any switches in series with the motor, would I use the AC or DC ratings of the switch?
My understanding is the biggest difference in the ratings between AC and DC switching for contacts is that the lack of a zero voltage/current diminishes the ability of the arc to break, hence why DC switching ratings are less than the AC ratings for a given set of contacts.
However, in this application, I still have the zero voltage/current so therefore I think I can use the AC ratings. Am I correct?
If you intend to use it for AC purposes then use the AC switch ratings. However, it's always better to overspecify the ratings even if it means spending a little bit more money. I recommend contacting company representatives directly with questions regarding their products.
If you place the switch in the AC line to the bridge you can use its AC rating.
If you have it on the DC side use its DC rating. Even though your applied DC voltage voltage dips to zero twice per cycle , the motor's inductance maintains current and the bridge acts like a flywheel diode..
Draw yourself a full wave bridge with inductive load and observe how the bridge completes a current loop for inductive "kick". But that feature really eases things for ths switch if it's on AC side of bridge.
Better safe than sorry.
Jim, that was awesome as always.
Well golly, md, thanks for the kind words !
Hope your project works out smooth .
old jim
