Triboelectric Charging Substance Selection
  • Context: Graduate
  • Thread starter Thread starter drerzaask
    Charging
To minimize triboelectric charging, select two materials that are close to each other on the Triboelectric Series scale, as this will result in minimal field lines and reduced charging. Factors such as speed of separation, friction, and relative humidity significantly influence the charging effect. Standard electrostatic discharge (ESD) prevention methods, including the use of grounded wrist straps and ESD safe mats, are essential for mitigating tribocharging effects. JA Polycarbonate, commonly used for CDs, is noted for its difficulty in charging through rubbing.
  • Understanding of the Triboelectric Series scale
  • Knowledge of electrostatic discharge (ESD) prevention methods
  • Familiarity with materials used in triboelectric applications
  • Basic principles of friction and charge generation
  • Research the Triboelectric Series and its implications for material selection
  • Explore advanced ESD prevention techniques and tools
  • Investigate the properties of JA Polycarbonate and its applications
  • Learn about ionization methods for charge removal
This discussion is beneficial for materials scientists, electrical engineers, and professionals involved in product design where triboelectric charging is a concern.
drerzaask
If I am trying to minimize triboelectric charging. What two substances when rubbed together would produce minimal field lines and minimal charging?
Any two dissimilar materials can and will tribocharge. The farther apart two materials are on the Triboelectric Series scale, the greater they will charge when separated. The speed of separation, friction (rubbing), and relative humidity will also effect how large the charge will be. Select your two materials close to the center and next to each other on the scale for minimum charging.
http://www.keyence.com/ionizer/feature/img/features03/img01.jpg
Are you trying to reduce the effects of tribocharging? If so standard electrostatic discharge prevention methods would go a long way. Using things like properly connected and grounded wrist straps, ESD safe (dissipative) mats, ESD safe lab coats, and wearing low-charging natural fiber clothing like cotton will help.
To effectively remove a charge requires use an ionizer or you can wait for charges to decay.
JA
Polycarbonate (used for CDs) is difficult to charge by rubbing it.
12K
  • · Replies 20 ·
