Linear Algebra - Jordan form basis
The discussion revolves around finding a Jordan basis for a given matrix A in the context of linear algebra. The original poster presents a matrix and its Jordan form, seeking to determine the vectors that satisfy specific eigenvalue equations.
  • The original poster attempts to find vectors v1, v2, v3, and v4 corresponding to the Jordan form but encounters difficulties in solving the equations. Some participants suggest considering linear combinations of existing vectors to find v3, while others question the validity of the original poster's method and propose alternative approaches involving kernel calculations.
Participants are exploring different methods to find the necessary vectors for the Jordan basis. There is acknowledgment of multiple approaches, with some participants expressing confusion about which method to adopt. The original poster has received feedback indicating that both methods discussed are valid, but they continue to seek clarity on their application.
There is an ongoing discussion about the independence of the vectors being found and the implications of using linear combinations. The original poster has also noted a discrepancy in the solutions obtained, leading to further questioning of the methods employed.
oferon
Hi all,
I'm having trouble finding jordan basis for matrix A, e.g. the P matrix of: [itex]J=P^{-1}AP[/itex]
Given [itex]A = \begin{pmatrix} 4 & 1 & 1 & 1 \\ -1 & 2 & -1 & -1 \\ 6 & 1 & -1 & 1 \\ -6 & -1 & 4 & 2 \end{pmatrix}[/itex]
I found Jordan form to be: [itex]J = \begin{pmatrix} -2 & & & \\ & 3 & 1 & \\ & & 3 & \\ & & & 3 \end{pmatrix}[/itex]
Now wer'e looking for [itex]v_1, v_2, v_3, v_4[/itex] such that:
[itex]Av_1 = -2v_1 → (A+2I)v_1=0[/itex]
[itex]Av_2 = 3v_2 → (A-3I)v_2=0[/itex]
[itex]Av_3 = v_2+3v_3 → (A-3I)v_3=v_2[/itex]
[itex]Av_4 = 3v_4 → (A-3I)v_4=0[/itex]
So now I find: [itex]v_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \\ -1 \end{pmatrix} \hspace{10mm} v_2,v_4 = \begin{pmatrix} 1 \\ 0 \\ 1 \\ -2 \end{pmatrix},\begin{pmatrix} 0 \\ 1 \\ 0 \\ -1 \end{pmatrix}[/itex]
Now I try to solve [itex](A-3I)v_3=v_2[/itex] for each of the possible v2's I just found above, but there's no solution for any of em'...
[itex]A = \begin{pmatrix} 1 & 1 & 1 & 1 \\ -1 & -1 & -1 & -1 \\ 6 & 1 & -4 & 1 \\ -6 & -1 & 4 & -1 \end{pmatrix}\begin{pmatrix} x \\ y \\ z \\ w \end{pmatrix}=\begin{pmatrix} 1 \\ 0 \\ 1 \\ -2 \end{pmatrix}\hspace{5mm} OR \hspace{5mm} A = \begin{pmatrix} 1 & 1 & 1 & 1 \\ -1 & -1 & -1 & -1 \\ 6 & 1 & -4 & 1 \\ -6 & -1 & 4 & -1 \end{pmatrix}\begin{pmatrix} x \\ y \\ z \\ w \end{pmatrix}=\begin{pmatrix} 0 \\ 1 \\ 0 \\ -1 \end{pmatrix}[/itex]Where am I going wrong? Thanks in advance!
Hi oferon! :smile:
Did you consider that the proper v2 could be a linear combination of your current v2 and v4?
What if you try ##\lambda v_2 + \mu v_4## to find v3?
If it was a linear combination of other vectors then V1-4 would not be a basis.. Am I wrong?
Plus, another student told me the method I tried was completely wrong and that the correct method is finding more vectors through
[itex]Ker (A-λI)^j[/itex] where j=2,3,... depends on how many more vectors I need for my basis.
Which of the methods should I use? Any why? I'm lost :confused:
You need to find a ##v_3## that satisfies ##(A-3I)v_3=λv_2+μv_4##.
When you find it, v1-v4 will form a basis.
That would work too, but it seems to me that it is a lot more work.
(Short story: that student is wrong. Your method is fine. You just did not finish it.)
If you're wondering... try both?
Hi, thanks for your kind replies.
Ok, first I try what you suggested.. I take [itex](A-3I)v_3 = λv_2+μv_4[/itex] I get:
[itex]\begin{pmatrix} 1 & 1 & 1 & 1 \\ -1 & -1 & -1 & -1 \\ 6 & 1 & -4 & 1 \\ -6 & -1 & 4 & -1 \end{pmatrix}\begin{pmatrix} x \\ y \\ z \\ w \end{pmatrix}=\begin{pmatrix} λ \\ μ \\ λ \\ -2λ-μ \end{pmatrix} ----> \begin{pmatrix} 1 & 1 & 1 & 1 \\ 0 & 0 & 0 & 0 \\ 6 & 1 & -4 & 1 \\ 0 & 0 & 0 & 0 \end{pmatrix}\begin{pmatrix} x \\ y \\ z \\ w \end{pmatrix}=\begin{pmatrix} λ \\ λ+μ \\ λ \\ -λ-μ \end{pmatrix}[/itex]
Now I see it must satisfy [itex]μ = -λ[/itex] so I pick [itex]λ=1, μ=-1[/itex] thus [itex]v_2-v_4=\begin{pmatrix} 1 \\ -1 \\ 1 \\ -1 \end{pmatrix}[/itex] so now I solve: [itex]\begin{pmatrix} 1 & 1 & 1 & 1 \\ -1 & -1 & -1 & -1 \\ 6 & 1 & -4 & 1 \\ -6 & -1 & 4 & -1 \end{pmatrix}\begin{pmatrix} x \\ y \\ z \\ w \end{pmatrix}=\begin{pmatrix} 1 \\ -1 \\ 1 \\ -1 \end{pmatrix}[/itex]
But the solutions I get are exactly [itex]\begin{pmatrix} 1 \\ 0 \\ 1 \\ -2 \end{pmatrix} , \begin{pmatrix} 0 \\ 1 \\ 0 \\ -1 \end{pmatrix}[/itex] The same v2,v4... So where am I wrong now?
Second thing, I've searched all over the net, and found this method. Yet the method the other student told me is what was taught in class. Can I be 100% sure both methods are equivalent and can be used both in all cases?
I thank you again for your time.
Ok, so I asked our instructor about the second question and yes, both methods are good.
I prefer "my" method, but as you can see I still get stucked with it.. So how do I move on with this [itex](A-3I)v_3 = λv_2+μv_4[/itex] ?
Thanks again
Can you find a 3rd solution that is independent of v2 and v4?
(Let's say with the first 2 entries set to zero. ;)
Hmm, ok I see what you say..
So now I have 3 final questions to close this case for good:
1) I thought all solutions were given by span of [itex]\begin{pmatrix} 1 \\ 0 \\ 1 \\ -2 \end{pmatrix} , \begin{pmatrix} 0 \\ 1 \\ 0 \\ -1 \end{pmatrix}[/itex]
So where did this [itex]\begin{pmatrix} 0 \\ 0 \\ 0 \\ 1 \end{pmatrix}[/itex] (tho I agree it IS a solution for this system) come from??
2) How is it possible that [itex]v_2 , v_4[/itex] are solutions of both homogeneous and non-homogeneous
[itex](A−3I)v_3=0[/itex] and [itex](A−3I)v_3=v_2-v_4[/itex]. I doubt if it was just by accident..
3) Final question is how come I'm allowed to go from the equation I got by comparing columns of PJ and AP: [itex](A−3I)v_3=v_2[/itex], ,
to the equation [itex](A−3I)v_3=λv_2+μv_4[/itex]?
The third column in J matrix [itex]\begin{pmatrix} 0 \\ 1 \\ 3 \\ 0 \end{pmatrix}[/itex] clearly shows I should find [itex]Av_3=v_2+3v_3[/itex] , not [itex]Av_3=v_2+3v_3-v_4[/itex]
I appreciate your help a lot! Thank you.
Oh ok, I discard my 3rd question... The answer is that I pick v2 to be [itex]\begin{pmatrix} 1 \\ -1 \\ 1 \\ -1 \end{pmatrix}[/itex]
Now I remain only with questions 1, and 2.. More related to equations system rather than J form I suppose
OK, please discard all of my question, I'm an idiot :)
Everything is clear now, I thank you very much for the last time :)
Okay... I just got around to looking at your thread again.
But it seems you've already answered your own questions.
Good! :smile:
