Solving Velocity Selector: E Field Direction for Proton & Electron
  • Thread starter Thread starter josephcollins
    Velocity
The direction of the electric field (E-field) in a velocity selector is determined by the charge of the particle being analyzed. For protons, the E-field is directed towards the negative plate, while for electrons, it is directed towards the positive plate. The polarity of the plates is contingent upon the direction of the magnetic field (B-field); if the B-field points towards the positive plate, the E-field will also point towards it, and vice versa. The right-hand rule can be employed to visualize these directions effectively.
  • Understanding of electric fields and magnetic fields
  • Familiarity with the right-hand rule for determining force directions
  • Knowledge of particle charges (positive for protons, negative for electrons)
  • Basic principles of velocity selectors in physics
  • Study the right-hand rule in detail for applications in electromagnetism
  • Explore the principles of velocity selectors in various physics contexts
  • Learn about the behavior of charged particles in electric and magnetic fields
  • Investigate the applications of electric and magnetic fields in particle accelerators
Physics students, educators, and professionals involved in electromagnetism, particularly those focusing on particle dynamics and velocity selectors.
josephcollins
Hi ppl,
I'm having a little trouble determining the direction of the E field in a velocity selector question. I can easily find the direction of the magnetic B field and the direction it forces a particle in. Once I do this, I know that the E field must oppose the force of the B field. The problem I have is determining the direction of the E field for a proton or an electron ( what the difference is) and also how to assign the polarity of the plates of the E field again for a proton and an electron.
Any help would be welcome, thanks, joe
In a velocity selector, the electric field (E-field) will always be perpendicular to the magnetic field (B-field). This means that for protons, the E-field will be directed towards the positive plate and away from the negative plate, while for electrons it will be in the opposite direction. The polarity of the plates will depend on the direction of the B-field. If the B-field is directed towards the positive plate then the E-field will also be directed towards the positive plate. Conversely, if the B-field is directed towards the negative plate then the E-field will also be directed towards the negative plate.
Hi Joe,
The direction of the electric field in a velocity selector is dependent on the charge of the particle being selected. For a proton, which has a positive charge, the electric field must be directed towards the negative plate of the selector. This is because the electric force on a positive charge is in the direction of the electric field. Similarly, for an electron, which has a negative charge, the electric field must be directed towards the positive plate of the selector.
To determine the polarity of the plates, you can use the right-hand rule. Point your thumb in the direction of the magnetic field, and your fingers will curl in the direction of the electric field. For a proton, the fingers will point towards the negative plate, and for an electron, the fingers will point towards the positive plate.
I hope this helps! Let me know if you have any further questions.
