Quotient Test for Convergence of Series
In summary: I don't see how this helps us to even apply the comparison test because we don't even know anything about the convergence of un or vn !Could you please explain in simpler terms? Thanks ε is an arbitrary positive number, for example 0.1. It is not a variable in the problem but a way of expressing that we can make the difference as small as we like by choosing a suitably large N. The two inequalities (ρ-ε)v_n<u_n<(ρ+ε)v_nsimply mean that u_n and v_n are "close" to each other, for large n. The point is, we know that v_n converges, and
unscientific
1,734
The quotient test can be used to determine whether a series is converging or not. The full description is in the attachment.
( i ) Why must they both follow the same behaviour? Even if p ≠ 0, it says nothing about the type of series Ʃu and Ʃv are! How can one so hastily conclude that if one converges, the other must too and if one diverges the other must too?
( ii ) If p = 0, won't it imply that the limit of un = 0 as n approaches infinity? So then series Ʃu must definitely converge. Why did they explain it the other way round (if Ʃv converges, then Ʃu must converge) Isn't Ʃu already known to be converging since limit un = 0 ?
( iii ) If p = ∞, won't it imply the limit of vn = 0 as n approaches infinity? (same case as in part (ii) )
Source: Extracted from Riley, Hobson and Bence " Mathematical Methods for Physics and Engineering " - Chapter 4: Series and Limits
If [itex]u_n/v_n[/itex] goes to [itex]\rho[/itex] we can say that, for n sufficiently large, [itex]u_n< (\rho+1)v_n[/itex] and, if [itex]v_n[/itex] converges, so does [itex]u_n[/itex], by the comparison test. Conversely, if [itex]u_n[/itex] diverges so does [itex]v_n[/itex]
No, that does NOT imply that un goes to 0. For example, if un= n and [itex]v_n= n^2[/itex], [itex]u_n/v_n= 1/n[/itex] which goes to 0 as n goes to infinity but both un and vn go to infinity. The denominator just goes to infinity faster than the numerator.
No, for the same reason as above. Take [itex]u_n= n^2[/itex], [itex]v_n= n[/itex].
First of all, thank you for replying to my enquiry! It is because of people as dedicated as you are so this site can keep going! (So students like myself can enrich our knowledge!)
However, I'm sorry to trouble you but it would be very kind of you if I could clarify some doubts.
HallsofIvy said:
If [itex]u_n/v_n[/itex] goes to [itex]\rho[/itex] we can say that, for n sufficiently large, [itex]u_n< (\rho+1)v_n[/itex] and, if [itex]v_n[/itex] converges, so does [itex]u_n[/itex], by the comparison test. Conversely, if [itex]u_n[/itex] diverges so does [itex]v_n[/tex]
No, that does NOT imply that un goes to 0. For example, if un= n and [itex]v_n= n^2[/itex], [itex]u_n/v_n= 1/n[/tex] which goes to 0 as n goes to infinity but both un and vn go to infinity. The denominator just goes to infinity faster than the numerator. No, for the same reason as above. Take [itex]u_n= n^2[/itex], [itex]v_n= n[/itex].
( i ) I don't understand how you can take
and simply apply the comparison test. I tried to break it down into cases:
Case 1: 0 < p < 1
un < vn (for n tends to infinity) implying:
1a. If vn converges, so must un.
1b. But if un converges, it says nothing about vn since un < vn.
2a. If un diverges, so must vn must diverge.
2b. But if vn diverges, it says nothing about un since un < vn.
Case 2: p > 1
Arrives at the same paradox..(ii)
That was a fantastic counter-example which made me realize that my thinking wasn't thorough enough. If you don't mind please tell me if my understanding is correct:
If p = 0,
It implies that vn increases at a faster rate than un such that eventually p → 0. So since vn > un for all n, then if vn converges then by comparison test un must converge!
(Would this also imply that if un diverges, then so must vn?)
(iii)
If p = ∞,
It implies that un increases at a faster rate than vn such that eventually p → ∞. So since un > vn for all n, then if vn diverges then by comparison test un must diverge!
(Would this imply that if un converges, so must vn?)
Mod note: Moved this thread to the Calculus & Beyond section, which is more appropriate than the Precalc section it was posted in.
Hopefully this might clear up some stuff,
Given [itex]\frac{u_n}{v_n}→ρ[/itex], by definition of convergence... we have for sufficiently large N, [itex]|\frac{u_n}{v_n}-ρ|<ε[/itex]
IE, [itex] (ρ-ε)v_n<u_n<(ρ+ε)v_n [/itex]
so if we pick ε<ρ for some N, we can guarantee comparison holds :-).
also, the other two problems are equivalent if you consider the reciprocal of the quotient of sequences.
this is ofcourse assuming for non negative sequences, ρ<0 would follow in a similar fashion with some slight adjustments
I'm sorry but i don't really understand what you just wrote.. first of all what is ε?
Secondly for [itex]|\frac{u_n}{v_n}-ρ|<ε[/itex],
all we arrive at is:
un < vn(p-ε)
or
un < vn(p+ε)
I think I have come up with a way to explain why as long as p ≠ 0 both series must accompany each other with same behaviour (assuming all terms are real and positive).since
[itex]\frac{u_n}{v_n}[/itex] → n as n → ∞, it implies that at
sufficiently large n,
[itex]\frac{un}{vn}[/itex] ≈ [itex]\frac{un+1}{vn+1}[/itex] and is truly reached when n = ∞.
Thus comparing the sequence:
un, un+1, un+2...
vn, vn+1, vn+2...
If the first sequence diverges or converges, the second sequence must therefore follow its pattern by the same ratio of ≈ p!
... Have you not done work with the definition of convergence? And that is definitely not how absolute values work... If I said |x-2|<1... That means 1<x<3...
Look up convergent sequence criteria
damn, my mistake. I put the ' - ' sign to the ratio instead of to ε! My bad!
I tried reading up on convergence: http://en.wikipedia.org/wiki/Limit_(mathematics )
But I don't seem to be making any progress.. not sure why I can't understand it
Here is the definition of convergence for a sequence.
in order for [itex]a_n→a[/itex] it follows that for all ε>0 there exists some N so that for natural numbers n>N, [itex]|a_n-a|<ε[/itex]
that is... as we get further out into our sequence, the behavior we'd see is that the sequence will get closer to it's limit, or the distance between the limit and the sequence will get smaller and smaller.
take [itex]|\frac{1}{n}-0|<\epsilon[/itex]... since 1/n→0,
that means we can pick any interval and find an N so that it works for all n>N
for instance... if we wanted to consider the case for ε=1/100...
[itex]\frac{1}{n}<\frac{1}{100}⇔n>100=N[/itex]
the same way we can do it with the quotient converging to ρ. Halls of Ivy specifically picked for ε=1 in this case.
I suggest though keeping ε<ρ, for positive sequences (makes it a lil prettier)
I get it now, thank you! But I don't see any relation in explaining how the inequality post explains why as long as p≠0 both series will be share the same behaviour..
If (p-e)*v_n<u_n,
(p-e)sum(v_n)<sum(u_n)
So v_n diverge implies u_n diverges. u_n converges implies v_n converges.
What is the Quotient Test for Convergence of Series?
The Quotient Test, also known as the D'Alembert's Ratio Test, is a method for determining the convergence or divergence of an infinite series. It compares the ratio of consecutive terms in the series to a limit value to determine if the series converges or diverges.
How is the Quotient Test used to determine convergence?
To use the Quotient Test, take the limit of the absolute value of the ratio of consecutive terms as n approaches infinity. If the limit is less than 1, the series converges. If the limit is greater than 1, the series diverges. If the limit is equal to 1, the test is inconclusive and another method must be used.
When should the Quotient Test be used instead of other convergence tests?
The Quotient Test is useful for series that involve exponentials or factorials, as well as series that alternate in sign. It should be used when the terms in the series are in a ratio that is easily simplified.
What are some limitations of the Quotient Test?
The Quotient Test can only be used for series with positive terms. It also cannot be used to determine the sum of a series, only its convergence or divergence. Additionally, the limit value may be difficult to find in some cases, making the test inconclusive.
How does the Quotient Test relate to other convergence tests?
The Quotient Test is similar to the Ratio Test, which uses the same principle of comparing the ratio of consecutive terms to a limit value. However, the Quotient Test is considered to be more powerful and can be used in cases where the Ratio Test fails. It is also related to the Root Test, which uses the limit of the nth root of the absolute value of each term instead of the ratio.
