New Reply
Modeling a bicycle
Share Thread
Jul2-12, 02:27 PM   #1
Modeling a bicycle
First off, this is not a homework question. I am simply trying to figure out how to make a discrete time model into a continuous one. I don't expect anyone to work this out for me, I just want to start heading in the right direction.
I have a model of a bicycle on a 2d plane that has a position (x,y) and an orientation (theta). Theta is with respect to the X axis. The bike steers with the front wheel at an angle (alpha) with respect to the orientation (theta). The distance between the rear wheel and the front wheel is L. Now, given an initial state (x,y,theta), I am given a distance the bike will travel (d) at a certain steering angle (alpha). It can be shown that the new position and orientation of the bike is as follows:
x' = cx + sin(theta+Beta)*R
y' = cy - cos(theta+Beta)*R
theta' = (theta+Beta) (%mod 2pi optionally)
where
cx = x - sin(theta)*R
cy = y + cos(theta)*R
R = d/Beta
Beta = d*tan(alpha)/L
Now what I want to do is generate a trajectory of the bicycle given an arbitrary time varying function for both the steering angle (alpha) and the instantaenous velocity d(d)/dt. How would I go about starting a problem like this?
If we ignore all the details that I listed above, I should be able to write the new position and orentation as a vector:
| x' |
| y' | = f(x,y,theta,alpha,d)
|theta|
What steps do I need to take next? When I move to a continuous model, all the variables become time varying: f(x(t),y(t),theta(t),d(t)). My first thought is that I take the derivative of each component with respect to alpha and d. I would then end up integrating from time zero to time T given the initial state vector and given time varying functions for alpha and d.
Thanks
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jul5-12, 08:40 PM   #2
Recognitions:
Homework Helper Homework Help
You cannot integrate arbitrary functions in closed form. For most, numerical solutions are all that's possible. I assume the issue you're worried about is accumulation of errors using a finite time step, but in general I doubt there's much can be done about that.
Jul5-12, 09:48 PM   #3
Hey hazuki and welcome to the forums.
Are you aware of how to derive stability constraints for differential equations?
This kind of analysis is done for numerical integration schemes and I suggest you get a reference source, be it a text or an online source for error analysis.
Also a suggestion would be to start with the simpler model and then generalize the parameter after you have done the analysis for the simpler version.
So in terms of the specifics, start with R being a constant. Then extend R to the definition and keep Beta a constant. Then allow Beta to be defined in the way its defined.
What background do you have with numerical techniques for integrating systems of differential equations?
New Reply
Similar discussions for: Modeling a bicycle
Thread Forum Replies
help me fix my bicycle General Discussion 19
Bicycle Introductory Physics Homework 2
Bicycle - HELP! General Physics 8
bicycle Classical Physics 5
Buy a bicycle General Discussion 24
