| New Reply |
Does physics forbid such a device; a heat destroyer |
Share Thread | Thread Tools |
| Jul15-12, 09:35 PM | #103 |
Does physics forbid such a device; a heat destroyerI haven't, I'll take a look at The Gods Themselves, thanks. |
| Jul16-12, 06:46 AM | #104 |
Mentor
| Jul16-12, 05:31 PM | #105 |
Clearly the best solution is not to be stupid enough to start a war in the first place.
edit: I actually think the future of this is a swarm of smaller drone-controlled units that can somehow co-ordinate their actions. I believe it's already a given that "human" pilots are history. This is however not fun to write about. |
| Jul16-12, 06:53 PM | #106 |
| Jul16-12, 07:31 PM | #107 |
But that is only the KE. The actual amount of energy released could be more. For one, the projectile could be made of anti-matter and it's density combined with it's velocity with guarantees high amount of particle-anti particle annihilation. 1 kilogram of matter turns into 21.481 megatons of energy, of course this is assuming a 100% annihilation figure which isn't even close to the actual, however, this energy would not be solely directed in path of the projectile, but radiate outward throughout the ship(in fact much of the KE energy would do this as well). If anybody is picturing such a projectile to simply knock a neat hole right through a ship, they would be horrible mistaken, there would be little left. In fact, it would not take many of such projectiles to render earth inhabitable. In effect, a relativistic mass-driver such as the .9999 C 1 kilo of antimatter design as outlined above would functionally be a laser that shoots planet killer level thermonuclear bombs. It is this fact, combined with that fact that a relativistic mass driver is on the lower end of the weapons theoretically possible that has led me to that classical sci-fi defensive mechanisms would be useless; armor isn't going to cut it, high maneuverability evasion of relativistic weapons doesn't seem likely at all without some sort of physics breaking propulsion engine(warp drive/higgs field blocker/etc) and there is no credible way to make a star-trek like shield with known physics(that I know of). I will say that swarms of small expendable unmanned drones would certainly be effective, but than again, you certainly wouldn't want such a swarm to find your ship, would you... |
| Jul17-12, 02:55 AM | #108 |
Mentor
It is well known in PET imaging that matter antimatter annihilation conserves momentum. The result is that the photons released do not simply radiate outward, but are angled toward the direction of the momentum. In this case, because the momentum is so high, they would be tightly collimated, and any that did go radially would have quite low energy. |
| Jul17-12, 03:59 AM | #109 |
Mentor
Interestingly, the dependence on the starting temperature of the heat sink is very non-linear. The above calculations are for 1. μK. For 2.7 K, a factor of ~3 million change, the time is 11 min, only a factor of ~4 change. |
| Jul17-12, 08:01 PM | #110 |
As far as the launcher itself, it would be trivial; on a ship that is traveling at a relativistic speed(which is not trivial, but certainly possible, especially with the fact that the ship can take a long amount of time to accelerate). The ship could also be a kill vehicle and be consisting of independent highly modular autonomous vehicles that could break apart into many different guided sections and/or launch an almost arbitrary number of filament bombs. Such a weapon would not have any difficulty at all rendering a solar system uninhabitable and/or destroying any detectible structures/ships, and moreover, such a vehicle is not fantastical in the least within the realm of hard sci-fi. It just seems like the only defense in space would be stealth(or perhaps diplomacy, but we all know how well that works in today's world). My current best design uses heat pumps to pull heat from across the ship and concentrate, then use a black-body pumped laser to lase energy in a very focused direction that I hope nobody will be listening, in addional to using heat sinks as you have suggestion with standard black-body radiator design when not in "stealth mode". |
| Jul17-12, 10:20 PM | #111 |
Mentor
| Jul18-12, 05:41 AM | #112 |
Mentor
In addition, your system to accelerate the ship is a weapon of mass destruction on its own. And you probably want a really powerful energy source. Direct antimatter annihilation would have the capacity, but is hard to store and handle (and imagine your storage getting hit by anything!) and probably give an exhaust visible even from other stellar systems (while this is not an issue due to the delay, it means that it is easy to spot for everything in the same system). Hawking radiation might be useful but gives a lot of heat to radiate away, and it is tricky to accelerate the black hole with 10g. |
| Jul18-12, 07:18 AM | #113 |
Mentor
http://en.wikipedia.org/wiki/Railgun |
| Jul18-12, 07:45 AM | #114 |
Mentor
Deeviant was talking about a ship, not a projectile. As the ship should have its own railgun, I would assume that it is too large to be launched by regular railguns.
In addition, even with an insanely oversized railgun, capable of accelerating a whole spaceship with 2000g, and a spaceship which can handle this, the acceleration track would be more than 1 million km long. At this size and in the inner solar system, the inhomogeneous gravity from the sun becomes significant. And it cannot "catch" the spaceship afterwards. |
| Jul18-12, 07:47 AM | #115 |
Mentor
| Jul18-12, 10:38 AM | #116 |
PS: If you think relativistic projectiles will induce fusion or antimatter reactions by virtue of the energy they deliver (which they might or might not do), then even one loose hydrogen atom, or one tiny grain of space dust, would cause detonation. How to ensure the projectile does not go BOOM inside, or close to, the launcher? (Also a crop sprayer on the front of the ship would be an effective defence while closing...) Also I think you really need to think about the engineering "difficultes" inherent with getting up to even 1/10th of light speed. Those are not simply going to go away with bigger drives. There is the Tsolikov Rocket Equation to consider. http://en.wikipedia.org/wiki/Tsiolko...ocket_equation In laymans terms, top speed of a ship in space is proportional to the exhaust velocity of the drive, and the fuel system has to conserve momentum. Which means the ship is going to be like 99.99% fuel or something and you need a drive with relativistic exhaust velocity. (Which will of course explode unless you edit: Actually i think that equation doesnt apply to relativistic speeds, upon reading further I see there is a relativistic version of it presented, however. |
| Jul18-12, 01:24 PM | #117 |
| Jul18-12, 03:32 PM | #118 |
Mentor
However, you could just use mirrors and optics to radiate the heat in a focused beam. So that isn't an "in principle" problem, just a "best practice" problem. |
| Jul18-12, 04:09 PM | #119 |
| New Reply |
| Thread Tools | |
Similar Threads for: Does physics forbid such a device; a heat destroyer
| Does SR actually forbid FTL travel? | Special & General Relativity | 102 | ||
| Work done and total heat transfer for piston-cylinder device | Engineering, Comp Sci, & Technology Homework | 1 | ||
| What does the theory of common descent forbid? | Biology | 1 | ||
| U.S. Destroyer chases pirate ship | General Discussion | 12 | ||
| The great destroyer: human or nonhuman nature? | General Discussion | 5 | ||
