Simplifying Vector Analysis Derivatives with \nabla \times \vec{A}: Expert Tips
The discussion focuses on simplifying the term \(\frac{\partial }{\partial \vec{A}} B^{2}\) where \(\vec{B}=\nabla \times \vec{A}\). Participants suggest expanding the cross product of the del operator and vector field \(\vec{A}\) to facilitate simplification. It is clarified that the components of \(\vec{A}\) and \(\vec{B}\) are intertwined, which complicates the simplification process. The derivatives with respect to a vector field are referred to as vector derivatives.
  • Understanding of vector calculus, specifically curl and cross products.
  • Familiarity with vector fields and their properties.
  • Knowledge of partial derivatives and their applications in vector analysis.
  • Basic grasp of determinant formulations in mathematical expressions.
  • Study the properties of vector derivatives in vector calculus.
  • Learn about the determinant formulation for expanding cross products.
  • Research the implications of intertwined vector components in vector fields.
  • Explore advanced topics in vector calculus, such as the application of curl in physics.
Mathematicians, physicists, and engineering students who are working with vector fields and require a deeper understanding of vector derivatives and their simplifications.
Hassan2
Dear all,
I have two vector fields [itex]\vec{B}[/itex] and [itex]\vec{A}[/itex] related by:
[itex]\vec{B}=\nabla \times \vec{A}[/itex]
How can I simplify the following term:
[itex]\frac{\partial }{\partial \vec{A}} B^{2}[/itex]
where [itex]\frac{\partial }{\partial \vec{A}}=(\frac{\partial }{\partial A_{x}} \frac{\partial }{\partial A_{y}} \frac{\partial }{\partial A_{z}} )[/itex]
I would also like to know what are this kind of derivatives ( derivatives with respect to a vector field) called.
Thanks.
Hassan2 said:
Dear all,
Thanks.
Hey Hassan2.
Try expanding out the cross product of del and A first.
Also when you say the vector derivative, are the elements of each vector mapped to the same corresponding element in the other? In other words if A = [x0,y0,z0] and B = [x1,y1,z1] then is x0 = f(x1), y0 = g(y1) and z0 = h(z1) (and the components are completely orthogonal)?
If this is the case, you will be able to expand del X A using the determinant formulation and simplify terms depending on how you define your elements of your vector (even if they are more general than above).
The elements of the vectors are NOT mapped correspondingly. In fact the first equation is the definition of B, thus, the components are intertwined.
I couldn't simplify it by expanding the curl.It results in partial derivatives of second order multiplied by partial derivatives of first order.
Thanks.
  • · Replies 16 ·
