New Reply
What are branes made of?
Share Thread Thread Tools
Jul3-12, 01:39 PM   #1
I'm not sure which forum these questions belong in, so the moderators should feel free to move this thread to wherever they deem appropriate.
I have some questions regarding branes. These questions are based upon a complete lack of understanding about the nature of branes, and as they build upon this fundamental lack of understanding some of them are no doubt completely ridiculous. Please answer any questions you choose, and ignore the others. The first two questions are the most important as the others are simply an extension of my view that D1-branes would have a positive and a negative end.
1. The most basic question I suppose, is what are branes made of, and what force holds them together?
2. Could it be said that a D1-brane has a positive and a negative end?
3. Would a vibration on a D1-brane flow from one end to the other, or would it be a standing wave?
4. Could energy of some sort be said to flow through a D1-brane under the right conditions?
5. If all the matter in our universe were sucked into a black hole, would it form a D0 or a D1 brane?
6. Could a D2-brane have a positive and negative aspect?
7. Rather than interacting at random could branes actually be attracted to each other?
8. Are black holes in some sense a D1-brane extended outward from a D2 or higher brane?
9. If so does a black hole then grow until it makes contact with another brane, at which time it's contents are discharged, in a sense similar to an electrical discharge into the other brane?
10. Could gravity be the attraction between two branes?
11. When two D2-branes interact do they combine to form a larger D2-brane, or would they in a sense become laminated to form a higher dimensional brane?
Sorry for all the stupid questions. But this is the best way that I have found to learn something. Read, ask questions, contemplate, and repeat.
Like I said the first two questions are the most important. I have many more questions, but any information that you can give would be appreciated.
Thanks
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jul4-12, 09:38 AM   #2
There are not made of anything. What is a knot on a rope made from? What is a hole in a cheese made from?
Branes in string theories are basic object in a sense. You could explain everything with them, but they themselves do not have any simpler explanation.
Yes, there are theories in which branes are oriented.
Both situations are possible.
Yes, the vibrations energy.
Uh, God only knows. Which theory are you referring to?
Yes, surfaces can also be oriented. But there are surfaces like a Moebius strip that have only one side and they can not be oriented.
Yes, they could and this is what string theories are about.
Once again: in which theory? But considering how many string theories there are I bet there is one where black holes are described just like that :).
Yes, in a sense that the gravity is a manifestation of some fundamental brane interaction.
They form another D2-brane.
Jul4-12, 05:25 PM   #3
Recognitions:
Gold Membership Gold Member
I disagree: Branes are multi dimensional strings and hence are composed of energy like strings. Ed Witten found that [M theory includes] such objects with p dimensions, meaning integer values from 0 to 10...and such p=branes are significantly heaver than strings.
In THE ENDLESS UNIVERSE, for example, Neil Turok and Paul Steinhardt describe forever colliding brane [energy] ripples from which collision irregularites in space and time produce the quantum fluctuations associated with 'bangs'....the start of another universe.
"Could a D2-brane have a positive and negative aspect?"
yes, but my understanding is not via 'charge'...rather by the nature of vibrational energy patterns. One end of an open string may 'behave' differently that the other end.
Jul5-12, 01:44 AM   #4
Quote by Naty1 View Post
What does it mean: "to be composed of energy"? Everything is composed of energy, so this sentence is just a tautology. Moreover, in string theories "energy" is not some basic entity whose properties are known for given. Rather, the branes are basic objects and the "energy" is explained in terms of branes.
Branes in string theories are the conceptually most basic objects, like axioms in mathematics. Their properties can not be described by anything more simple, be it energy.
Jul5-12, 08:21 AM   #5
Recognitions:
The OP can decide whether he likes 'nothing' or the energy perspective of Kip Thorne, Leonard Susskind, Paul Steinhardt, Neil Turok, Roger Penrose, Brian Greene...,,,,well you get the idea....
In any case, the 'energy' description is useful because different energy vibrational patterns of strings result in different observational patterns, like mass, charge, spin,etc.
New Reply
Thread Tools
Similar Threads for: What are branes made of?
Thread Forum Replies
What Are Branes? Beyond the Standard Model 6
Cells are made of molecules,molecules are made of atoms,atoms are made of energy.so.. Biology 9
How Branes Came To Be? Beyond the Standard Model 83
