X(t) of a diatomic molecule with given v_0
The problem involves two identical carts connected by a spring, with one cart initially moving and the other at rest. The objective is to find the position of the moving cart as a function of time, considering the dynamics of the system.
  • Exploratory, Assumption checking
  • The original poster attempts to derive the equations of motion for the carts and expresses uncertainty about their approach. They also plan to apply initial conditions to find the position function.
  • Participants question the definitions of variables and the choice of origin, as well as the assumptions made in the problem setup.
There is a mention of the need for initial conditions, and the original poster has not yet specified the origin or all assumptions related to the problem.
AbigailM
Two identical carts (of mass m) are free to move on a frictionless, straight horizontal track. The masses are connected by a spring of constant k and un-stretched length [itex]l_{0}[/itex]. Initially the masses are a distance [itex]l_{0}[/itex] apart with the mass on the left having a speed [itex]v_{0}[/itex] to the right and the mass on the right at rest. Find the position of mass on the left as a function of time.
[itex]q=x_{2}-x_{1}-l_{0}[/itex]
[itex]\dot{q}=\dot{x_{2}}-\dot{x_{1}}[/itex]
[itex]\ddot{q}=\ddot{x_{2}}-\ddot{x_{1}}[/itex]
[itex]m\ddot{x_{1}}=-k(x_{2}-x_{1}-l_{0})[/itex]
[itex]m\ddot{x_{2}}=k(x_{2}-x_{1}-l_{0})[/itex]
remembering [itex]\ddot{q}=\ddot{x_{2}}-\ddot{x_{1}}[/itex]
[itex]\ddot{q}=\frac{2k}{m}q=\omega^{2}q[/itex]
[itex]q(t)=c_{1}e^{\omega t}+c_{2}e^{-\omega t}[/itex]
Just wondering if I'm on the right track? If so I'll do the initial conditions and then solve for [itex]x_{1}(t)[/itex]
Thanks for the help!
Hi AbigailM! :smile:
It would help if you state what x1 and x2 are... :-p
:eek: oops, x1 is the position of cart 1 and x2 is the position of cart 2.
What have you chosen as the origin? I believe q is the elongation/compression of the spring? Is cart 1 the left cart, and cart 2 the right?PS : Its good to state all assumptions before solving the problem :wink:
