| New Reply |
How do airplanes really fly |
Share Thread | Thread Tools |
| Jul7-12, 09:23 PM | #18 |
| Jul7-12, 09:34 PM | #19 |
Mentor
| Jul7-12, 09:39 PM | #20 |
| Jul7-12, 11:25 PM | #21 |
Just as in a car, wind resistance increases as the square of speed, so, in a plane, does lift. |
| Jul8-12, 09:17 AM | #22 |
Holy cow there are some huge misconceptions here.
In a most basic sense, lift can be explained through Newton's laws. The flow is "pushed down" do the plane must be "pushed up". Of course in this sense, it doesn't matter how this downwash is generated or how efficiently, only that it is generated. Bernoulli's principle is one way to calculate the lift on a wing in certain situations (the wing cannot be separated, for example). Given a velocity distribution over a wing, you can use Bernoulli's equation to deduce the pressures on the wing and hence the lift. It says nothing about how you find sai velocities or the best shape of a wing. Bernoulli's equation is merely a tool; it cannot explain lift completely. Now, any wing that generates lift must, by definition, deflect the air downward, and the same wing will also have a higher pressure below than above. You can connect the two using what is called the Kutta condition. This states that for an object with a sharp trailing edge, the rear stagnation point must be at that trailing edge rather than the location predicted by inviscid methods, which results in a net circulation around the airfoil and therefore a velocity difference and pressure difference on the surfaces as well as deflected flow coming off the back. This works for any shape with a sharp trailing edge (as all wings have) and does not require any assumptions about how the plane is flying. A plane with a symmetric airfoil can fly because it has angle I attack and a sharp trailing edge. This allows the airfoil to deflect the flow downward. The same applies for a traditional airfoil flying upside down. In this case, flying inverted is her inefficient, but with enough angle of attack it can be done. Flying vertically doesn't have lift in the traditional sense. The lift is provided solely by the thrust. |
| Jul8-12, 09:24 AM | #23 |
Mentor
| Jul8-12, 09:25 AM | #24 |
Mentor
| Jul8-12, 09:51 AM | #25 |
| Jul8-12, 03:07 PM | #26 |
Recognitions:
| Jul8-12, 04:31 PM | #27 |
Mentor
| Jul8-12, 04:32 PM | #28 |
The wing only adds energy to the air through the action of viscosity since the wing therefore drags some air along with it. That creates drag, though, not lift. |
| Jul8-12, 04:37 PM | #29 |
Mentor
| Jul8-12, 04:54 PM | #30 |
I'm afraid this subject (is it Bernoulli or Newton) comes up all the time on forums around the world. People argue strongly. For every person who favours one theory there is another that has the opposite view.
It's a false dichotomy. Neither is right or wrong. http://www.pprune.org/professional-p...li-newton.html |
| Jul8-12, 05:01 PM | #31 |
http://www.grc.nasa.gov/WWW/k-12/airplane/bernnew.html
This site was posted on PF and I read it a while back and felt that it was informative. It has a simple explanation on the first page and some deeper stuff on the second. My recollection is that it says that either a freebody force explanation or bernoulli fluid laws can work. But it helps to clarify the common mistakes that are made. I haven't the time to reread it now, so I hope that it is as I remember (if its not lets pretend that they changed it since I read it) |
| Jul8-12, 05:07 PM | #32 |
| Jul8-12, 06:17 PM | #33 |
Recognitions:
A similar process occurs with a propeller or rotor, except that the pressure differential is greater than a typical wing, and there is a greater amount of induced flow (the inwash ahead of the propeller or rotor). From a NASA article: ... at the exit, the velocity is greater than free stream because the propeller does work on the airflow. We can apply Bernoulli's equation to the air in front of the propeller and to the air behind the propeller. But we cannot apply Bernoulli's equation across the propeller disk because the work performed ... propanl.htm |
| Jul8-12, 08:53 PM | #34 |
| New Reply |
| Thread Tools | |
Similar Threads for: How do airplanes really fly
| RC Airplanes | General Discussion | 0 | ||
| propeller airplanes vs jet airplanes | Aerospace Engineering | 10 | ||
| Why airplanes really fly | Classical Physics | 14 | ||
| why do airplanes fly? | Classical Physics | 97 | ||
| how do planes fly inverted? | General Physics | 2 | ||
