New Reply
Heat funnction in steady state
Share Thread
Jul5-12, 07:39 AM   #1
I was given the following interesting question.
A closed room contains several identical machines in it, they are fed by an electrical cable.
The machines can be turned on or off. When a machine is turned on, it consumes electrical energy and as a by product generates heat. The heat is radiated through the room walls to the outside air.
What is the function that describes the room surface temperature in steady state as a function of the number of machines that are turned on? Is it power 2 or 3 of β (the number of machines that are turned on)?
In order to simplify the analysis you can assume that the room is a ball.
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
New Reply
Tags
heat radiation, temperature
Similar discussions for: Heat funnction in steady state
Thread Forum Replies
Calculating Steady State Heat Transfer Introductory Physics Homework 1
modified heat equation steady state Calculus & Beyond Homework 4
Steady state heat flow Precalculus Mathematics Homework 1
Steady state heat conduction problem Advanced Physics Homework 2
steady state heat conduction Classical Physics 1
