| New Reply |
Strength training while dieting = weight gain? |
Share Thread | Thread Tools |
| Jul5-12, 08:20 PM | #1 |
The title is a bit deceptive but I've been very curious about something that many people who diet have found. Over the course of a few months, I was losing weight at a steady pace of 2lb/week. At one point I decided to make the most of my gym membership and start doing resistance training as well for around 30 minutes twice a week. The weight loss just stopped dead in its tracks. I never gained weight (unlike what a lot of people said happened to them) but my weight loss definitely slowed to a crawl.
Everywhere online and everyone I talk to says that this is to be expected, but why on Earth does this happen? My understanding of physiology is pretty bad, but I figured that, as you lose weight, your body is going through fat for the energy to run your body. If nothing else changes and you start resistance training, why exactly does weight loss stop (or even reverse)? You're still giving your body less energy than it needs to run on, so why does this happen? TELL ME STUFF SCIENCE!!!!! |
| Jul5-12, 08:46 PM | #2 |
Admin
With weight training, one builds muscle. Muscle is denser than fat so that one can reduce one's size, but retain mass (weight).
With exercise, one uses energy (calories). Did one also reduce caloric intake, or even increase food intake? |
| Jul5-12, 08:52 PM | #3 |
I had the same caloric deficit before and during the training. This is what I don't understand. I was losing weight for a good 5 months prior to this.
| Jul5-12, 08:55 PM | #4 |
Admin
| Jul5-12, 09:20 PM | #5 |
Nope not that I remember.
| Jul6-12, 12:08 AM | #6 |
In the absence of burning it off, any fat you eat is stored as fat. Likewise with most carbs.
What about protein? Is protein ever stored in any way except as muscle? My suspicion is that you are now retaining that protein portion of your diet that was previously being eliminated without being used. At the same time you are burning off fat you are adding muscle mass from the protein in your food, protein that you previously weren't using to repair the muscle damage of exercise. In other words, your caloric debt was greater than you thought before you started exercising because you weren't even using the protein you were taking in. That's my guess. Otherwise I'd have to say Penguins just aren't normal. |
| Jul6-12, 03:15 AM | #7 |
Well this was a while ago. I stopped the resistance training and the weight has been coming back off just like it was before I did the training.
I think penguins aren't normal. |
| Jul6-12, 10:50 AM | #8 |
You mentioned that you started resistance training. This where your body changes into conserve mode. This happens initially whenever someone starts any exercise. That is the body tries to conserve, when for the same calories intake you are burning more. This a natural body mechanism, similar to a situation in starvation (lack of calories). This is the best, i can come up with. Maybe somebody else has a better explaination. |
| Jul6-12, 03:56 PM | #9 |
Maybe I'm misunderstanding you, but if you are taking in the same calories as before and are doing resistance training on top of what you normally did before, then it shouldn't decrease the rate of weight (fat) loss. If anything, and all other things being equal, it should slightly increase the rate of weight (fat) loss because you're burning more calories than before. Having said that, as one's weight decreases it becomes progressively harder to lose weight (fat) because a lower body weight requires a lower amount of maintenance calories. At 160 lbs. you would need to consume less calories to maintain that body weight than when trying to maintain a bodyweight of 180 lbs. So if you want to continue losing weight, as you body weight decreases, you sorta have to either continually exercise more (increase output) and/or eat less (decrease input) or a combination of the two. After a while it becomes very difficult. Again, I might be misunderstanding you?
| Jul6-12, 04:00 PM | #10 |
| Jul9-12, 03:28 AM | #11 |
Before taking a serious look at the why of your body mass dynamics, we need to acknowledge the unknown variables:
Without controlling for all variables (and the above aren't "all," they are just the more significant ones), we will always have little inconsistencies in what we see and be unable to explain them since we can't seem to tease them out, like you said. Without knowing more, here are a few things that are relatively constant
so without knowing more, every guess anyone will come up with would be no different from the nautical practice of "dead reckoning"... it's better than chance, but not by much. and if you really don't want to delve deeper and want some wild guesses, try these:
hope this helps. here's one more. |
| Jul9-12, 10:35 AM | #12 |
http://jama.jamanetwork.com/article....icleid=1199154 |
| Jul9-12, 01:18 PM | #13 |
The interaction between macro-nutrients, metabolism (catabolism + anabolism), energy expenditure (REE, TEE, exercise), and hormones is quite fascinating, and I would invite you to read more on it because there is no question that macronutrients affect different folks differently at a molecular level.
The problem is extrapolating this to the whole-body level since the math gets more complicated. As for the JAMA study you cited, you should read Dr. Attia's analysis of the 2012 JAMA study as he can break it down like a champ.. not to mention he actually knows and talks to Dr. Ludwig (not Lustig), who I've listened to a few of his lectures too! Much of the misunderstanding and false assumption that a calorie is a calorie comes from Kinsell's 1964 study where he tested 5 obese subjects. He varied their macronutrient ratios wildly but kept the calories below maintenance and at the same amount. In the end, he showed that the subjects all lost weight at the same rate regardless of macronutrient ratio. The big problem with Kinsell's study (other researchers have since pointed this out) is that his patients were not representative of the general population (3 were Type 2 diabetics, one had epileptiform seizures, one had a pituitary cancer, one was taking thyroid meds). The other point was that the subjects were placed on a very low calorie (800 - 1200 / day) diet. Very low calorie diets (below 1200/day) begin to look alike in the body because at such a calorie deficit, the body goes into "starvation" mode regardless of macronutrients: thus, hormones are usually trumped. The study had many more problems, but in time, other researchers "forgot" these weaknesses (that had been known since 1965) and only considered the low calories = weight loss regardless of macronutrient claim. Many later studies since then have refuted Kinsell, but it takes dozens of good studies to fully refute a single bad study that intellectually lazy people fall in love with, if they ever let go of it at all... It reminds me of a quote i can't fully recall, but I like. It goes something like this: |
| Jul9-12, 02:06 PM | #14 |
Regardless, now after this study I'm very confused and at the same time very interested. |
| Jul10-12, 09:31 AM | #15 |
being confused is good... it means you're at least searching for understanding in a sea of information.
Keep in mind that the whole debate over "a calorie is a calorie" depends on how you want to frame this statement:
Entropy is not the only reason for the difference, though. There is an even greater factor that Buchholz did not address: humans are not JUST biochemical machines . if we were, the question of dieting would not exist. Humans gain weight mostly due to intake and secondarily due to indolence. let me repeat: humans gain weight mostly due to intake and secondarily due to indolence. But the folks who only look at biochemistry already know that. the problem is they keep their thinking on a biochemical level and simply assume that "putting the fork down" or "moving your behind" is the solution. If we were machines (like your car), it would be.Sadly, we are powerfully attracted to sweet, fatty, salty, and soft foods because these foods are more likely to be energy dense and easy to eat, and this feeds a need that has been hard-wired into our evolved bodies over hundreds of millions of years! for 99.99999% of our evolutionary history (way back to the first tetrapods), sweet, fatty, salty, and soft foods were rare so that nature limited our access to them... as such, we developed a "bloodhound nose" for anything that might have these traits: I can smell baking bread a mile away! Today such foods are plentiful and cheap, but our hormones are still wired to assume such occurrences are rare and so when we come across them, we gorge ourselves. our hormones are well adapted to detecting such foods, but poorly adapted to regulating our intake: if for 99.99999% of our evolutionary history nature limited our intake of such foods, why would our bodies need to evolve regulatory mechanisms to limit our intake of such foods? (ok, we need some, but not much). This also explains why humans lost the ability to synthesize ascorbic acid while other mammals can: because primates ate plenty of fruits such that the loss of gulonolactone oxidase (the final Vitamin C synthesis enzyme) was not a problem; we got more than enough vitamin C from nature. the moral: why make enzymes to regulate something when nature provides the regulation for you (positive or negative)? This explains why for many of us, food is more than just a fuel... it's a love affair.
With so many emotional reasons and the ubiquity of food and sources of it, calorie maintenance becomes, NOT a matter of calories in, calories out, but of understanding its impact on your behavior (e.g., you're not a robot): The positive (negative) feedback loop: This poor regulation of food first leads to weight gain and that weight gain results in hormone imbalances that are even more conducive to weight gain: getting fat makes it easier for you to get fatter for two reasons:
In such an imbalanced environment, is it any wonder that dieting is such a Sisyphean task, almost always doomed to fail? Not convinced? go look up the failure rates for dieters and compare them to the failure rates for alcoholics and opiate addicts. hint: they're all more or less the same!This human behavioral aspect is conveniently overlooked in most diets and studies on diets, yet it more than accounts for the difference in diet effectiveness for a few reasons:
in short, the behavioral effects of certain foods, particularly sweet and soft foods (junk foods) affects more than our biochemistry. studies that try to control for this may only report the biochemical effects of food, but food is not gasoline... it's tasty, delicious, and we'd do so much for it! And there IS a biochemical advantage to low carbohydrate diets, we know this from theory and from empirical research (see the 2012 JAMA article in a previous post, 2004 Buchholz, 2004 Volek, 2007 Gardner below and pay close attention to the results in their tables). It's just that this effect is often overwhelmed by our behavioral effects, both in the short term (cheating, lying) and in the long term (hormonal dysregulation, insulin resistance). Finally, to be fair, human variation dictates that some of us will have adequate regulation, either due to tight biochemical or hormonal control, poor access to junk food, or being too busy to indulge. These are the folks we love to hate because they are naturally skinny for many such reasons that we wish we had. sources:
| Jul10-12, 10:16 AM | #16 |
I got a chance to look over that JAMA 2012 study. One of the weaknesses of this study can be found in the methods section:
1. Do you think that an extra 300 kcal/day expenditure on the low-carb isocaloric diet over the higher-carb in the JAMA 2012 study seems a bit too impressive to be true? Especially given that: 2. Are you aware of even 1 controlled ward study that shows higher expenditure with an isocaloric, lower carb diet? I think there was a review I had looked before of such ward studies and all showed little to no advantage, if I'm not mistaken? By the way, I'm no fan of the high carb diet. I do find many of the processed ones very addictive and a constant struggle but that is another issue. |
| Jul10-12, 02:53 PM | #17 |
One big dis-advantage of the low-carb (if it = high-protein) diet is increased likelihood of kidney damage though this appears to be mostly in those with reduced kidney functions: http://www.webmd.com/diet/news/20030...n-hurt-kidneys . However, as this article points out, many people have reduced kidney function but don't know it.
| New Reply |
| Thread Tools | |
Similar Threads for: Strength training while dieting = weight gain?
| Does an object gain weight??? | General Physics | 7 | ||
| I need to gain weight... | Medical Sciences | 17 | ||
| Physics and Weight Training Questions | General Physics | 6 | ||
| So how much weight did you gain? | General Discussion | 29 | ||
| Weight gain question | Medical Sciences | 15 | ||
