A physics related computer question
  • Context: High School
  • Thread starter Thread starter bobewalton
    Computer Physics
Heat does not react in a vacuum, as it primarily transfers through conduction and convection, which are absent in such an environment. The discussion highlights that using a vacuum for a computer case would trap heat, contrary to the intention of cooling it. Instead, utilizing airflow and fans is recommended for effective heat dissipation in computer systems.
  • Understanding of thermodynamics principles, specifically heat transfer mechanisms.
  • Familiarity with computer cooling systems and their components.
  • Knowledge of vacuum environments and their properties.
  • Basic concepts of thermal insulation, such as those used in thermos bottles.
  • Research thermal management techniques in computer systems.
  • Learn about the principles of heat transfer: conduction, convection, and radiation.
  • Explore the design and functionality of active cooling systems, including fans and heat sinks.
  • Investigate the effects of vacuum environments on electronic components and their thermal performance.
Computer engineers, thermal management specialists, and anyone involved in designing or optimizing cooling solutions for electronic devices.
bobewalton
[SOLVED] A physics related computer question
How does heat react in a vacuume? The though I am having is to make a computer case that is a vacuume and to then remove heat on the exterior of the case. Basically, how does heat act in a vacumme is my question and will it build up? Thank you all for your help.
Science news on Phys.org
Heat doesn't "react" at all in a vacuum!
To answer your actual question, consider the "thermos" (that's a trademark!) bottle. You put hot soup in the bottle and it stays hot!
While a small amount of heat can escape by radiation, most heat moves by conduction or convection. You can't have either of those in a vacuum.
Your idea of putting a computer in a vacuum would make things worse! You would be "bottling" the heat produced up in the computer rather than taking it away. Far better to allow air to pass through (and use a fan to help it along).
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 28 ·
