How Do You Calculate Torque and Angular Momentum in a Conical Pendulum?
  • Thread starter Thread starter carl87
    Momentum Torque
The discussion revolves around calculating torque and angular momentum for a conical pendulum setup involving a ball on a string. The problem specifies parameters such as mass, string length, and angle with the vertical, leading to questions about the relationships between forces and motion in this context.
  • Mixed
  • Participants explore the calculation of torque and angular momentum, with some attempting to derive equations based on the forces acting on the ball. There is a discussion about the correct interpretation of torque and the role of gravitational force. Others question the assumptions made regarding the radius and the velocity of the ball.
Some participants have provided calculations and insights into the relationships between the forces, while others are seeking clarification on specific steps and concepts. The conversation reflects a mix of correct approaches and misunderstandings, with no clear consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There is an ongoing examination of the definitions and relationships between torque, angular momentum, and the forces involved in the conical pendulum scenario.
carl87
A ball (mass m = 250 g) on the end of an ideal string is moving in a circular motion as a conical pendulum. The length L of the string is 1.84 m and the angle with the vertical is 37 degrees.
a) What is the magnitude of the torque (N m) exerted on the ball about the support point?
b) What is the magnitude of the angular momentum (kg m^2/2) of the ball about the support point?
Correct Answers: a) 2.71 b) 1.32
L = m * v * r (where L = momentum)
F centripetal = (mv^2) / r
weight = mg
torque = r vector x F vector
For A I assumed the torque was 0 because there wasn't any said force. This obviously was wrong but I do not know why.
For B I used L = m*v*r where L = momentum
First I drew out the diagram.
I noticed r = L * sin 37
I noticed m*g*tan 37 = (m * v^2 /r)
m = .250 kg
v = (r * g * tan 37 )^(0.5) = (L*sin 37*9.8*tan 37)^(0.5) = 2.8596
r = L * sin 37 = 1.84 * sin 37= 1.10733
Plug and chug:
L = .791 This was incorrect.
Please help!
Thanks
Okay I found out that torque = L * force . The force is gravity!
1.84 x .250 * 9.8 X sin(180 - 37) = 2.71
r needs to be 1.84. The length of the string. Got it!
We know that torque is calculated in the following way.
[itex]\sum_i^n \overline{T_i} = \sum_i^n \overline{r} \times \overline{F} _i[/itex] (1)
Also we know that there are two external forces that are applied in the ball:
The tension of the string:
[itex]\overline{T} = -T \widehat{x}[/itex]
And the weight:
[itex]\overline{P}= mg(cos \gamma \widehat{x} - sin \gamma \widehat{y})[/itex]
Also we know that the position of the ball (b) from the support point (s) is the length of the string, we define it in the following way:
[itex]\overline{r_{sb}} = L \widehat{x}[/itex]
[itex]\overline{r_{ss}} = 0 \widehat{x}[/itex]
Remember that the distance from the support point to the support point is zero, so with all these information we can use (1):
[itex]\sum_i^n \overline{T_i} = \sum_i^n \overline{r} \times \overline{F} _i = \overline{r_{sb}} \times mg(cos \gamma \widehat{x} - sin \gamma \widehat{y}) + \overline{r_{ss}} \times (-T) \widehat{x}[/itex]
Rewriting:
[itex]\sum_i^n \overline{T_i} = L \widehat{x} \times mg cos \gamma \widehat{x} + L \widehat{x} \times - mg sin \gamma \widehat{y} + 0 \times (-T) \widehat{x}[/itex]
[itex]\sum_i^n \overline{T_i} = L \widehat{x} \times - mg sin \gamma \widehat{y}[/itex]
Replacing all the data that we have:
[itex]| \sum_i^n \overline{T_i} | = (1.84 m)(9,8 \frac{m}{s^2})(0.250 kg) sin 37° \approx 2.7129 Kg \frac{m^2}{s^2}[/itex]
For item b we know that angular momentum is defined as:
[itex]\sum_i^n \overline{L_i} = \sum_i^n \overline{r_i} \times m \overline{v_i}[/itex] (2)
I am not seeing how you determined that the velocity of the ball is:
[itex]v^2 = r*g*tan 37[/itex]
Can you explain it?.
Centripetal F = mv^2 / r.
This force can also be written in terms of weight and the angle:
mgtan 37
Set them equal to each other;
mgtan(37) = mv^2 /r
Cancel m:
gtan(37) = v^2 / r
Simplify for V^2:
rgtan(37) = v^2
  • · Replies 17 ·
18K
