New Reply
Timber beam moment/deflection
Share Thread Thread Tools
Jul12-12, 09:39 AM   #1
Hello everyone,
I have a question regarding the moment and deflection calculation of this handrail beam that I have. I am attaching a picture to give you guys a look at what I am working with.
The hand railing is 4" x 4" and it is not attached half way, its just resting on that beam, it is however attached with a bolt at the bottom. My question is, when im looking for the resisting moment would I take 89/2 in the section modulus calculations or the full 89mm. Same goes for deflection, when I do the moment of inertia, would I do the full 89 mm or 89/2. If it is 89/2 then how would I incorporate the rest of the beam in the resisting moment/deflection or would it have no effect on it?
any help would be greatly appreciated, thanks!
http://tinypic.com/r/lzmh2/6
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Jul12-12, 11:42 PM   #2
nvn
Recognitions:
Homework Helper Homework Help
blackbird2552: In general, it appears you would use (89 - 38) = 51 mm, and 0.5*51, in the section modulus calculation, for the bending stress calculation. You would also use 51 mm in the moment of inertia calculation, for the deflection calculation. The 89 mm portion of the handrail beam would have little or no effect on the deflection.
Jul13-12, 07:55 AM   #3
Thank you so much! that is exactly what i needed confirmed and also thanks for clearing up my concept.
New Reply
Tags
timber beam
Thread Tools
Similar Threads for: Timber beam moment/deflection
Thread Forum Replies
Beam bending problem, calculate deflection of a beam Engineering, Comp Sci, & Technology Homework 7
Deflection of a beam Mechanical Engineering 5
Beam deflection in a cantilever beam Mechanical Engineering 3
Maximum deflection in a timber beam Introductory Physics Homework 2
