New Reply
Simulink USS block - probability analysis
Share Thread
Jul12-12, 12:55 PM   #1
Here are the basics - I've got a model with a computed distance between 2 objects. The likelihood that object A will detect object B is a probability dependent on distance (and its a cumulative lognormal curve).
I want to include a probability function based on that computed distance. So that at X meters, the probability of detection is 20%. At Y distance its 50% etc. At each step of the model, the distance will be different, so it needs to redo its random draw from the probability function and output whether or not object B was detected.
I was under the impression that the uncertain state block within the robust control toolbox was the direction to go, but so far I haven't been able to decipher the "help" information to learn how to use and apply it. (And as far as I can understand, it would be ideal b/c I can also run the model varying all the uncertain variables a certain number of times from the command line).
HELP PLEASE!!!
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
New Reply
Tags
matlab, probability, robust control, simulink
Similar discussions for: Simulink USS block - probability analysis
Thread Forum Replies
Probability analysis in Simulink model Set Theory, Logic, Probability, Statistics 5
How to display a real time graph in the Matlab GUI from simulink block Engineering, Comp Sci, & Technology Homework 1
Creating 4x4 Matrix Block in Simulink Engineering, Comp Sci, & Technology Homework 2
block diagram in simulink Engineering, Comp Sci, & Technology Homework 0
The integration block in simulink Calculus 1
