Rudin Theorem 3.23: Proving the Limit of Terms is Zero
  • Context: Graduate
  • Thread starter Thread starter jecharla
    Theorem
Theorem 3.23 states that if a series converges, then the limit of the terms of the sequence is zero. The discussion critiques Rudin's justification, arguing that his use of the Cauchy criterion with n = m does not sufficiently demonstrate that a_n approaches zero. Instead, the argument suggests that using n = m - 1 is necessary to show that a_m approaches zero. Ultimately, the consensus affirms that Rudin's logic holds when properly interpreted through the lens of Theorem 3.22.
  • Understanding of convergence in series
  • Familiarity with Cauchy sequences
  • Knowledge of Theorem 3.22 from Rudin's "Principles of Mathematical Analysis"
  • Basic concepts of limits in sequences
  • Study the implications of Theorem 3.22 in detail
  • Explore the properties of Cauchy sequences and their applications
  • Review proofs of convergence criteria in real analysis
  • Investigate further examples of series convergence and their limits
Mathematics students, educators, and anyone studying real analysis, particularly those focusing on series convergence and limit theorems.
jecharla
Theorem 3.23 is a very simple one: it says that if a series converges then the limit of the terms of the sequence is zero. However Rudin's way of justifying this fact doesn't seem valid to me. He uses the following logic:
A series converges if and only if the sequence of partial sums is cauchy meaning that for all ε > 0 there is an integer N s.t. for all n,m > N and n <= m the sum of the terms of the sequence from a_n to a_m is less than ε.
Rudin says that the case where n = m proves this theorem. However when n = m the only thing the cauchy criterion states is that the distance from a_n to a_n approaches zero. It does not actually say that the value of a_n approaches zero.
To prove this we need the case where n = m - 1.
Then the difference between the two partial sums is a_m and therefore a_m approaches zero.
Am I wrong?
Am I wrong?
Yes, I think you are. In theorem 3.22, Rudin proved that
[tex]\sum_{n=1}^\infty a_n\,\,\text{converges iff}\,\,\forall\epsilon >0\,\,\exists N\in \Bbb N\,\,s.t.\,\,\left|\sum_{k=n}^m a_k\right|<\epsilon\,\,\,\text{whenever}\,\,m\geq n\geq N[/tex]
If we accept this (and I can't see any reason *not* to accept it), then we can take [itex]\,n=m\,[/itex] , from where we get that if the series converges then
[tex]\forall \epsilon >0\,\,\exists\,N\in\Bbb N\,\,s.t.\,\,\left|\sum_{k=n}^n a_k\right|=|a_n|<\epsilon\,\,\,\text{whenever}\,\,\,n\geq N[/tex] which is exactly the definition of "the sequence [itex]\,\{a_n\}\,[/itex] converges to zero".
Please do note that in the last part above we do NOT have the "iff" of theorem 3.22, since we're limiting [itex]\,m=n\,[/itex], yet the necessary part, of course, remains valid.
DonAntonio
  • · Replies 44 ·
  • · Replies 0 ·
