How Does Current in a Wire Create a Magnetic Field?
The discussion revolves around the question of why current in a wire produces a magnetic field and how Maxwell related electricity and magnetism. The scope includes conceptual explanations and historical context regarding the interrelation of these phenomena.
  • Exploratory, Conceptual clarification, Historical
  • One participant asks for a simple explanation of why current in a wire produces a magnetic field and how Maxwell connected electricity and magnetism.
  • Another participant suggests that these topics are well-covered in existing literature and provides links to external resources.
  • A different participant proposes an explanation based on relativity, stating that the contraction of space between fixed positive charges leads to a perpendicular force related to the electric current.
  • Another response emphasizes the contributions of various historical figures, like Faraday, in understanding the relationship between electricity and magnetism, noting that currents and charges act as sources of electric and magnetic fields.
  • This participant also mentions the complexity introduced when fields are time-dependent, indicating that the relationship between electric and magnetic fields can be intricate.
Participants do not reach a consensus on a single explanation for the phenomenon, and multiple viewpoints and approaches are presented without resolution.
The discussion includes varying levels of complexity in explanations, with some participants suggesting that the relationship between electric and magnetic fields is more complicated when considering time-dependent changes.
sambarbarian
hi , i wanted to ask why does current in a wire produces a magnetic field ?
and can anyone explain how maxwell related electricity and magnetism , easily (im in high school)
It can be elegantly explained via relativity;
From the point of view of electric current, the space between (fixed) positive charges contracts, whereas the density of the negative charge is unchanged. This results in a force that is perpendicular to the direction of the electric current.
Claude.
As well as Maxwell, there were many others who showed the inter-relation between electricity and magnetism (for example, Faraday). I guess this was the result of both experiment, and the imagination of these people to make the connection between electricity and magnetism. Probably you can go on wikipedia and search these people's names, and it will tell you specific examples of several of the ways in which they related electricity and magnetism.
About the current in the wire, you should think of currents and charges as sources of the magnetic and electric fields (in a certain sense of the word). Specifically, a charge will cause an electric field to flow into (or out of) the volume enclosing that charge. And a current (through some cross-sectional area) can cause a magnetic field to flow around that area. Also, the electric field depends on changes in the magnetic field and vice-versa, so if the fields are time-dependent, then it is a little more complicated.
  • · Replies 22 ·
