New Reply
Cylinder oscillating in water.
Share Thread Thread Tools
Jul14-12, 01:12 PM   #1
ω1. The problem statement, all variables and given/known data
A cylinder of diameter d floats with l of its length submerged. The total height is L. Assume no damping. At time t = 0 the cylinder is pushed down a distance B and released.
What is the frequency of oscillation?
2. Relevant equations
[itex] f = ω/2\pi [/itex]
[itex] Ma = F_{(bouyancy)} [/itex]
Writing this in our differential form, making proper substitutions, and noting that bouyancy is affected by the distance that our cylinder is submerged we come to.
[itex] dx^2 (M_{(cylinder)}) + x (\rho_{(water)} g Area_{(cylinder face)})= 0 [/itex]
we know that [itex]M_{(cylinder)} = V_{(cylinder)}\rho_{(cylinder)} [/itex]
hence we should have
[itex] ω^2 = (\rho_{(water)} g Area_{(cylinder face)}) / V_{cylinder}\rho_{(cylinder)} = g\rho_{(water)} / l \rho_{(cylinder)}[/itex]
however the solution in my problem set has ω^2 = g/l. Can anyone shed some light on why the densities may cancel??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jul14-12, 01:30 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi ozone!
Quote by ozone View Post
[itex]g\rho_{(water)} / l \rho_{(cylinder)}[/itex]
(that's the same as g/L)
i haven't followed what you've done, but i'd guess you've used the wrong expression for the mass of the cylinder
just use a (vertical) force equation for the cylinder (at depth l + x)
Jul15-12, 10:42 PM   #3
the mass of the cylinder is the density of the cylinder times the area.. but the force from the water depends only on the density of water.. that is why i don't understand how the densities are cancelled out.
Jul15-12, 11:00 PM   #4
Recognitions:
In the denominator of your final expression for ω2, is that a small l or a capital L?
You can find an expression for the ratio of the two densities in terms of the ratio of l and L by considering the condition for equilibrium when length l of the cylinder is submerged.
Jul16-12, 09:07 AM   #5
that would be the lower case l in the solution set answer. You can view it for yourself at this link on page 4.
http://ocw.mit.edu/courses/physics/8...ents/sol1b.pdf
Jul16-12, 09:41 AM   #6
Recognitions:
But in the expression that you derived: ω2 = gρw/lρc, you should have a capital L rather than a lower case l in the denominator. Then you should be able to show that this expression reduces to the correct answer.
Jul18-12, 07:28 AM   #7
We never learned about fluid dynamics in my mechanics class, but I am guessing that the water displaced in equilibrium is equal to the mass of the cylinder?
Jul18-12, 08:12 AM   #8
Recognitions:
Yes. Archimedes Principle: Buoyant force = weight of fluid displaced
In equilibrium, Buoyant force equals the weight of the floating object.
New Reply
Thread Tools
Similar Threads for: Cylinder oscillating in water.
Thread Forum Replies
The period of water oscillating in a U-tube General Physics 2
Change in Gravitational Potential Energy in Oscillating water mass Advanced Physics Homework 1
Effect of oscillating magnetic field on diamagnetic water Electrical Engineering 0
A Sphere Oscillating in the Bottom of a Cylinder Introductory Physics Homework 2
Frequency of oscillating cylinder Introductory Physics Homework 2
