Electric field on a point charge
The discussion centers on calculating the electric field at a point near three point charges: 7.35 µC, 4.32 µC, and -3.42 µC, with the constant k valued at 8.98755 x 10^9 N m²/C². The user attempted to compute the electric field at a point 1.01 cm to the left of the middle charge using the formula E = k * q / r² for each charge. The user reported an approximate result of -3.2517 x 10^8 N/C, which was incorrect according to the system. The confusion arose regarding the distances used for calculating the electric fields from each charge.
  • Understanding of Coulomb's Law and electric fields
  • Familiarity with point charge configurations
  • Knowledge of unit conversions (cm to m)
  • Basic algebra for summing vector quantities
  • Review the principles of superposition in electric fields
  • Learn about vector addition of electric fields from multiple charges
  • Study the concept of electric field direction and magnitude
  • Practice problems involving electric fields from multiple point charges
This discussion is beneficial for physics students, educators, and anyone interested in electrostatics and electric field calculations involving point charges.
Electro
Hello guys,
I have a question which I think I solved it right but I don't understand why the final answer is wrong.
Here's the problem: Consider three charges as shown. k is 8.98755 * 10^9 N m^2/c^2. What is the electric field at a point 1.01 cm to the left of the middle charge? Ans. in N/C.
For the figure: O---------O-------O; seems like this. The charges are: (beginning from the left) 7.35, 4.32, -3.42 microCulombs. Distances The left to Middle is 4.92 cm and Middle to Right is 4 cm.
So, the most left is positive, the middle is positive and the one in the right is negative. The point P is 1.01 cm to the left of the middle particle.
What I did:
E1 = [k*(7.35*10^-6)]/(0.0492-0.0101)^2
E2 = the same thing, with its parameters (but this is toward -x-axis)
E3= the same, toward + x-axis
Then I add this up and I get approx. -3.2517*10^8 N/C
Actually this is not the answer (at least the System says so)
Please take a look at this thing, maybe there's sth tiny I don't get.
Thanks
what is the distance you use for E2 and E3?
For E2 i.e the middle one, I used just 1.01 cm (actually 0.0101 m) and for E3 4cm + 1.01 cm, which is 0.0501 m.
  • · Replies 68 ·
9K
  • · Replies 32 ·
