| New Reply |
Can a magnetic fields/forces do work on a current carrying wire?! |
Share Thread | Thread Tools |
| Jul30-12, 07:27 AM | #171 |
Can a magnetic fields/forces do work on a current carrying wire?!Paper you cited describes power density as "E dot J". Integrating over volume gives power. I've already affirmed that that is correct. To have current in the loop 2 types of work on the electrons are needed. We need to do work on the e- to transition it from valence to conduction band. Only E can do that. Second, when the e- loses energy due to lattice collisions, i.e. resistance, the E force restores this energy by doing work on the E. If not for loop current, there would be no B force. So, E is all important & indispensable. Nobody is denying the important role played by E force. Without it, the motor does not operate. But the force spinning the loop is indeed B force, not E. Please show me the component of E in a direction radial to the loop. Which Maxwell equation applies here? My diagram accounts for I, J, E, B, A, & velocity u. You keep citing that paper w/ the integral of E dot J. That integral proves that the work done by E is along the path of the current density J. But torque is normal to the current, where E dot J equals ZERO. I recommend you draw a diagram for your own understanding. All you do is cite that integral, which clearly proves my case. BR. Claude |
| Jul30-12, 09:16 AM | #172 |
Mentor
1) On page 1 you have the field B1 pointing in the wrong direction (or maybe the current I1 is in the wrong direction). 2) On page 2 it is not correct that [itex]E=-\frac{\partial}{\partial t} A[/itex]. Because the curl of the divergence of any scalar function is 0 you can add the divergence of an arbitrary scalar to E and still satisfy [itex]\nabla \times E = -\frac{\partial}{\partial t}(\nabla \times A)[/itex]. However, by assuming that everything is uncharged, I suspect that you can use Gauss' law and the remaining gauge freedom to set the divergence of the scalar function to 0. 3) On pages 3 and 4 it seems that, since both loops are in-plane Fm squeezes the loop without producing any torque or spin. It is an equilibrium position, however it is an unstable equilibrium and any deviation from being in plane will provide a torque. So, it is not critical. So, overall I agree with the conclusion. The E-field provides the work and the B-field provides the torque. |
| Jul30-12, 09:19 AM | #173 |
Mentor
If you weren't even trying to say that then the fact that increasing the current increases the rotor's magnetic field is even more irrelevant to the work done. Per cabraham's analysis, increasing B increases the torque, but it is still E.j which does the work. |
| Jul30-12, 09:29 AM | #174 |
2) Yes, I am aware that there is not a 1 for 1 equivalence, that uncharged de-energized conditions have to be assumed for my equation to be absolutely valid. 3) I did not do a great job drawing the loops. They are supposed to be oblique, but my lousy drawing skills ended up making them look co-planar. Based on the co-planar appearance, you are right, there would be zero torque, & a little motion either way results in non-zero torque. Thanks for your feedback, we are in agreement. One point needs to be clarified however. I agree that E does provide the work when it comes to producing loop current, since work is done elevating valence e- into conduction, & restoring energy lost due to lattice collisions, which is resistance. E does this exclusively. We agree that B produces torque. But remember that torque times angle equals work. B does rotational work equal to torque times radian angle measure. Torque, however, would be 0 if current were 0. But current is nonzero due to E. So B does rotate the loop, but its torque would not exist w/o J, which would not exist w/o E. BR. Claude |
| Jul30-12, 11:23 AM | #175 |
I like were this is going. Work is done by E.j and torque is by the B field. Good conclusion + agreement. |
| Jul30-12, 11:31 AM | #176 |
| Jul30-12, 12:18 PM | #177 |
Mentor
| Jul30-12, 12:20 PM | #178 |
Mentor
| Jul30-12, 01:37 PM | #179 |
1st bold: Agreed. E dot J is the work done by E. But why do you say that this work is split between rotor conduction thermal loss & mechanical energy? You're making a pure assumption. E dot J is the conduction loss, thermal, of the rotor. The current in the rotor is needed or else there is no B force to spin the rotor. 2nd bold: Where it went is into rotor loss, conduction current squared times resistance. That is all of it. "E dot J" cannot be what produces torque. Torque acts radially to the loop, whereas E dot J is tangential. Refer to my picture. I made it clear that E and J are in the wrong direction to produce torque. To produce torque we need a radial force, i.e. normal to current density J. E is along the J direction. Any component of E normal to J has ZERO dot product with J. 3rd: Agreed. The energy B used to do the work had to come from somewhere. We are in agreement thus far. Hopefully we are still in agreement when I say that the independent power source driving the motor (battery, wall outlet, car alternator, etc.) is replenishing the B energy. No field, E, B, whatever, can supply energy long term. Just as the input power source replenishes the B field energy, it also replenishes E field energy as well. As the B magnetic poles align, energy is minimum, & energy maxes out when the poles are 90 degrees apart. But the input supply is providing current as well as voltage. The product times the power factor times the efficiency is the amount of power processed by the fields, B as well as E. Like I said, E & B both do short term work. But the input power supply is doing the long term work. The energy from the supply is stored in B & E fields, transferred to charges & torque*angle, then said E & B field energy is replenished by the power source. Ultimately all the energy is provided by this input power source. But fields such as B & E provide us with a means of focusing & controlling the energy & transfer. The winding length, number of turns, air gap, core shape, etc. allow us to modify the motor behavior based on the application. But in all cases the power source driving the input does all the work. BR. Claude |
| Jul30-12, 02:18 PM | #180 |
We can write:
V-E=IR (v=supply voltage,E=back emf,I=current,R=resistance) From this we can write: VI=EI+I^2R VI=power supplied,I^2R resistive heating power losses and EI=mechanical power output. (A more detailed treatment would consider the other energy losses due to friction etc) Sorry if this is irrelevant to the discussion. |
| Jul30-12, 02:56 PM | #181 |
Cabraham:
from post 171:We need to do work on the e- to transition it from valence to conduction band. Only E can do that. Can you give me some idea of the width of the energy band between Valence and conduction bands in something like copper that you would use in any analysis? From most recent post: But the input supply is providing current as well as voltage. The product times the power factor times the efficiency is the amount of power processed by the fields, B as well as E. I am fimiliar with the concept of power factor in the analysis of AC circuits containing R, L and C but I have not met the idea applied to DC electric motors.... Can you amplify on this or quote a reference that I could access? And.... how do you define efficiency in your analysis. Looking forward to any explanations you feel able to give. |
| Jul30-12, 03:08 PM | #182 |
I was referring to ac motors as far as power factor goes. For dc motors, power factor can still have meaning. For example, if the input is a pure dc voltage source, but the current is a square wave, I've heard "power factor" defined as "pi/4". The dc pedestal current times the dc voltage is the continuous average power we are familiar with. But the ac ripple current times the voltage integrates to zero real power. Thus the ripple component of current does not contribute to motor output mechanical power. Again, I was implying ac motors whenever PF is computed. But with dc motors, or other types of load, the term "power factor" can still have meaning. It differs from the R-L-C definition of power factor. With R-L-C networks, PF is cos of phase angle between I & V. However, in switching power converters, a rectified waveform has a power factor involving fundamental line frequency & all harmonics. I.e. a full wave bridge rectifier outputs fundamental & harmonic frequencies, current & voltage. Power factor is defined as real power over total power. Reactive power is due to products of I & V of differing frequency. Or it can be due to same frequency I & V with 90 degree phase difference. I hope I've answered your question. BR. Claude |
| Jul30-12, 03:31 PM | #183 |
You have 'answered' my questions but not completely satisfactorily....sorry.
'Most electrons are already in the conduction band and need no work done on them'...that is what I thought. How does this affect your presentation? A lot of confusion regarding power factor !...you have 'heard it defined' as pi/4... definitions are not communicated by hearsay.... where is it published as pi/4 I did not realise that AC motors were implied in what you have produced...sorry. Also, I am not certain what is meant by this phrase: ' & energy maxes out when the poles are 90 degrees apart'.....is this a recognised technical term? |
| Jul30-12, 03:49 PM | #184 |
Recognitions:
To make it clear once again: I never denied that magnetic fields cause forces and also torques, but what has this to do with the fact that the magnetic field does not do work on charge and current distributions (including magnetization currents)! I think, in principle we agree now on this simple fact.
BTW: I don't like to draw diagrams but to use vector calculus since this is far more save.
| Jul30-12, 04:31 PM | #185 |
The original question enquired as to whether a magnetic field or force can work on a current carrying wire and the answer is yes it can.The answer is nicely illustrated in the labelled sketch(in the opening post) which shows a force(F=BIL) on each of the two opposite sides of the coil.F=BIL is found by using F=BeV and calculating the total force on all of the current carrying electrons in the length of conductor under consideration.In fact it is the total magnetic force.
If memory serves correctly F=BIl is used to define magnetic flux density which is used to define the Tesla which,in turn,is used to define the Ampere. The motion of the electrons within the conductors is affected by the B field as is evidenced by the Hall voltage which is set up if there are constraints to the movement of the coil. It should be remembered that the B field is not just that due to the permanent magnets or field coils only.There is also a major contribution to the field because of the current flowing through the coil.The resultant field is sometimes referred to as the "catapult field". |
| Jul30-12, 09:51 PM | #186 |
Mentor
If you are correct on that fact, then I agree with your reasoning. If I am correct on that fact, do you agree with my reasoning? |
| Jul30-12, 11:07 PM | #187 |
Unfortunately for my lack of experience with maxwell's equations I can't product a good argument based on what Dale + Van are saying... Thanks to Claude his showing the other side of things. Again this is going more deeper and more interesting! |
| New Reply |
| Thread Tools | |
Similar Threads for: Can a magnetic fields/forces do work on a current carrying wire?!
| Can a magnetic field do work on a current-carrying piece of wire? | Classical Physics | 8 | ||
| Magnetic Force in a Current Carrying Wire | Introductory Physics Homework | 1 | ||
| Rod of current wire exerting magnetic force on current carrying bar | Introductory Physics Homework | 0 | ||
| Magnetic force on a current carrying wire | General Physics | 2 | ||
| Magnetic Forces on Current-Carrying Wires (in magnetic fields). Is answer correct? | Introductory Physics Homework | 2 | ||
