| New Reply |
Can a magnetic fields/forces do work on a current carrying wire?! |
Share Thread | Thread Tools |
| Aug4-12, 02:44 PM | #307 |
Recognitions:
Can a magnetic fields/forces do work on a current carrying wire?!Maxwell's equations, and the Lorentz Force Law both deal with vector fields. If you don't understand how to take the inner product of two vector fields, you don't fully understand Maxwell's equations. Now, as for whether Magnetic field/forces do work on any classical system, the answer is fundamentally no. This assumes only that you take Maxwell's equations and the Lorentz force law as the basis for classical electrodynamics (which 99.9% of the current physics community likely does). In many cases, the work done on an object depends on the value of the magnetic field applied to it, but this does not mean that the magnetic field is directly doing the work (and it isn't!). |
| Aug4-12, 02:54 PM | #308 |
Respectfully submitted, Steve |
| Aug4-12, 03:14 PM | #309 |
Recognitions:
/sarcasm |
| Aug4-12, 06:18 PM | #310 |
| Aug4-12, 06:44 PM | #311 |
You are just 1 more talker who says "Claude you're wrong!" but then fails to follow through & show why I'm wrong. Prove your case, until you do all you offer is emoty word. Clauide |
| Aug4-12, 06:47 PM | #312 |
Recognitions:
| Aug4-12, 06:55 PM | #313 |
Recognitions:
| Aug4-12, 06:58 PM | #314 |
How do you explain that one? Remember that the energy in a motor that transfers from stator to rotor is chiefly in the air gap. If the energy was all confined to the wire, how does it transfer? The stator L has a flux which is in the stator iron core, links to the rotor iron core via the air gap. This flux is energy, LI2/2. This energy does not appear in the E.J product inside the wire. An example which is simpler to visualize is a 120 volt xfmr secondary driving a heater. The secondary winding resistance is 0.10 Ω, & the heater R is 11.9 Ω. The total is 12 Ω. Current is 10 amps. The power inside the secondary winding is 1.0V * 10A = 10W. If we only consider the inside of the sec winding, we get 10W, instead of 1200W total. Why is that? The voltage across the sec terminals depends on path taken. Outside the Cu it is 119V, inside it is 1.0V. To get the total power you need to consider both. When both are accounted for we get 10 + 1190 = 1200W, the right answer. Once again we appear to agree on almost everything but for the inside/outside question. I will search for the text & post. BR. Claude |
| Aug4-12, 07:06 PM | #315 |
Recognitions:
| Aug4-12, 07:47 PM | #316 |
Mentor
| Aug5-12, 01:31 AM | #317 |
| Aug5-12, 02:02 AM | #318 |
Recognitions:
Specifically, the force on an ideal dipole [itex]\mathbf{m}[/itex] is derived (typically as an example in a textbook or as an exercise for the student - c.f. Problem 6.4 from Griffith's Introduction to Electrodynamics 3rd edition ) from the Lorentz force law by treating the dipole as a limiting case of a current loop (with current [itex]I[/itex] running through it), as the vector area [itex]\mathbf{a} \equiv \oint \mathbf{ \hat{n} } da [/itex] scribed/enclosed (subtended?) by the loop is shrunk to zero in such a way that the product [itex]\mathbf{m}=I \mathbf{a} [/itex] remains unchanged. Thus [itex]\mathbf{F}=\nabla( \mathbf{m} \cdot \mathbf{B} )[/itex] is regarded as a composite force law in the sense that it can be derived from the Lorentz Force Law and Maxwell's equations, like every other EM force law, and not a pure magnetic force. The work on a dipole in an external magnetic field must once again come directly from the electric field that maintains the current, which is produced by an unknown (classically) energy source (Of course, permanent dipoles like those associated with an electron's spin are really a quantum phenomenon, but classically they are treated as described) |
| Aug5-12, 02:11 AM | #319 |
of course,but the result is of more general character then for any current loop.there is a mechanical energy associated with it amount to -m.B.the potential energy of the dipole from where the force formula comes.
| Aug5-12, 02:21 AM | #320 |
Recognitions:
[tex]\vec{E} \cdot \vec{j}=\vec{E} \cdot (c \vec{\nabla} \times \vec{M}).[/tex] In fact you can derive the coupled set of equations of motion for fields and matter by using the fundamental conservation laws from space-time symmetry, i.e., for total energy, momentum, and angular momentum. |
| Aug5-12, 03:18 AM | #321 |
The section starting with "the general idea" is the point that interests me most.It might be considered as trivial because it is to do with definitions.It all boils down to the question: Is the force F as given by F=BIL a magnetic force? I find your notes above confusing.Reference to a "composite force" seems to suggest that it is not a magnetic force,so what,if anything,should it be described as? In a previous post I suggested(if I remember correctly)that it could be described as an electromagnetic force. The notes go on to express an integral in terms of Fmag.net and then describe this as as "the magnetic force on an object".So is it a magnetic force or not?(A quick google lead me to the hyperphysics text book which described it as a magnetic force) If the wire contained just one moving electron BIl would equal Bqv, so if BIl is not regarded as the fundamental magnetic force it could be argued that nor is Bqv.For N electrons F=NBqv=BIl.The electrons may be in a wire which restricts their movements but the force on each one is still Bqv. |
| Aug5-12, 05:30 AM | #322 |
1.Can the force BIl do work? 2.Would you describe BIL as a magnetic force or otherwise? Thanks if you can find the time to answer. |
| Aug5-12, 06:39 AM | #323 |
My take on the original op question is that a magnetic field can exert torque but do no work.
If a put a weight on a frictionless horizontal bar I can increase or decrease at will the torque or moment around each support without input of any effort/work/joules. So torque and work done are different concepts. If I hold 2 equal poles of a permanent magnet close together and let go the 2 magnets will push each other away and therefore it looks like the magnetic fields are doing work. However in the process of flying apart there are always electrical fields involved, since there are travelling magnetic fields. The Poynting vector shows the flow of energy. The question of HOW energy reaches the rotor of a motor is an entirely different problem. From: http://arxiv.org/abs/1207.2173 Just to make again another point: LI2/2 does exist but has nothing to do with the output power of a motor. Asked for references are in short supply. |
| New Reply |
| Thread Tools | |
Similar Threads for: Can a magnetic fields/forces do work on a current carrying wire?!
| Can a magnetic field do work on a current-carrying piece of wire? | Classical Physics | 8 | ||
| Magnetic Force in a Current Carrying Wire | Introductory Physics Homework | 1 | ||
| Rod of current wire exerting magnetic force on current carrying bar | Introductory Physics Homework | 0 | ||
| Magnetic force on a current carrying wire | General Physics | 2 | ||
| Magnetic Forces on Current-Carrying Wires (in magnetic fields). Is answer correct? | Introductory Physics Homework | 2 | ||
