| New Reply |
Can a magnetic fields/forces do work on a current carrying wire?! |
Share Thread | Thread Tools |
| Aug10-12, 12:19 PM | #375 |
Mentor
Can a magnetic fields/forces do work on a current carrying wire?!"Everything should be made as simple as possible, but no simpler" - Albert Einstein |
| Aug10-12, 02:06 PM | #376 |
I feel its more of a perfected answer now. |
| Aug11-12, 01:19 AM | #377 |
Recognitions:
The answer is an unanimous "no". Period!
| Aug11-12, 03:27 AM | #378 |
Weekend has come and I want to add some concluding remarks.
If a science author writes:……….the force on a car causes it to move uphill against gravitational pull………, does the author imply that this force also provides energy? Or does he merely use everyday language to indicate forces involved, without really feeling if necessary to point out that a force doesn’t provide the energy required. To point out things like that each time, only spoils the flow of thought and does nothing to clarify an explanation. However, in a discussion such as this it should be pointed out that force and energy are not the same thing. If you believe otherwise then give me a rough calculation of how many Joules there are to the Newton. |
| Aug11-12, 09:22 PM | #379 |
Here it is, as promised, albeit 2 days late. Finally got around to it. I learned something interesting, never discussed in the thread, but came out when drawing a picture. Like I say, drawing the pic, examining forces, etc. sure does help. I recommend to all to carefully examine this paper before responding. I hope you like it. Cheers.
Claude |
| Aug13-12, 04:53 AM | #380 |
| Aug15-12, 03:48 AM | #381 |
Or do you actually agree with Miyz on this point, with your saying that "Of course the origin of the force/torque is the magnetic field. I've never denied this"? ![]() I just came back from vacation and see that you now uploaded a new one, which I did not yet study. Do you maintain the above conclusion or do you now agree with Dalespam?
| Aug15-12, 08:45 AM | #382 |
Recognitions:
Again, from a classical em.-point of view the magnetization is described by a current distribution either,
[tex]\vec{j}_{\text{max}}=c \vec{\nabla} \times \vec{M}.[/tex] |
| Aug16-12, 09:04 AM | #383 |
Hey everyone!
How about joining this thread here!(Talk's about magnets doing work on another magnet) Glade to open another fantastic discussion over there! Please do join!
| Aug29-12, 03:51 AM | #384 |
Surely you realize that a current loop is a magnet; the answers that you get there should be consistent with the answers here. So, as several others already concluded, I now reach the same answer here as there. The answer is YES: Magnetic force can do work on a current loop by means of magnetic attraction, as a current loop can be pulled in by the inhomogeneous field of a permanent magnet. In detail: if oriented properly then there is a net Lorentz force by the magnet on the current loop towards the magnet. The misconception that magnetic fields can do no work likely comes from particle physics (magnetic fields cannot do work on freely moving charges because the magnetic force is always perpendicular on the motion). PS suddenly the picture of your first post is visible again: and yes, also for that case, following the definition of work in Wikipedia, http://en.wikipedia.org/wiki/Work_%28physics%29: As the Lorentz force displaces the wire in the direction of the force, it "does work" according to that definition (and how that is possible has been discussed already). |
| Aug29-12, 05:24 AM | #385 |
Mentor
| Aug29-12, 06:54 AM | #386 |
| Aug29-12, 07:13 AM | #387 |
Mentor
| Aug29-12, 07:34 AM | #388 |
*such a weird law should prescribe complete and instant magnetic force disappearance for a current loop, but none at all for an electron in a cyclotron! |
| Aug29-12, 08:26 AM | #389 |
Your theory that the motion creates an E field which does the work cannot be right. The work needed to generate said E field comes from where? The torque on the loop is due to Lorentz magnetic force, Fm = qvXB. E does do work setting up the loop current. This current makes the torque possible. Without E, there would be no loop magnetic dipole & no motion. The Fm vector spins the loop. E vector keeps the loop current & magnetic dipole going. It's too easy. The fact that this is controversial amazes me. Claude |
| Aug29-12, 01:29 PM | #390 |
It's a logical impossibility for an effect to be its own cause; a force that is induced by motion cannot be driving that motion. |
| Aug29-12, 06:26 PM | #391 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: Can a magnetic fields/forces do work on a current carrying wire?!
| Can a magnetic field do work on a current-carrying piece of wire? | Classical Physics | 8 | ||
| Magnetic Force in a Current Carrying Wire | Introductory Physics Homework | 1 | ||
| Rod of current wire exerting magnetic force on current carrying bar | Introductory Physics Homework | 0 | ||
| Magnetic force on a current carrying wire | General Physics | 2 | ||
| Magnetic Forces on Current-Carrying Wires (in magnetic fields). Is answer correct? | Introductory Physics Homework | 2 | ||
