| New Reply |
In what year do you learn GR? |
Share Thread | Thread Tools |
| Jul19-12, 03:13 PM | #35 |
| Jul19-12, 03:16 PM | #36 |
| Jul19-12, 03:29 PM | #37 |
Mentor
| Jul19-12, 03:36 PM | #38 |
| Jul19-12, 11:01 PM | #39 |
The reason that GR isn't taught very much in comparison to QM is that for all but a few specialist problems, it's not that necessary, and you can get by with either ignoring it, or having a specialist give you "cookbook" equations. |
| Jul19-12, 11:10 PM | #40 |
For my Ph.D. supernova code, I had a GR module which I used to confirm that GR didn't make a difference. Once I confirmed that, then I ran everything else using Newtonian gravity, because it was a waste of CPU cycles which could be used to calculate something else. |
| Jul20-12, 02:24 AM | #41 |
Wow, I'm surprised that people didn't take GR. You'd think that people would want to learn gravity to the degree that they learn electromagnetism, as both are introduced in introductory course (well, one is a full semester, while one is probably only a chapter :P).
As others have said, if you want to study GR, go with Carroll's text. Good luck! |
| Jul20-12, 06:48 AM | #42 |
It not a question about what you want to know . It is what you need to know. A good grasp of EM is absolutely essential to every working physicist, simply because EM is used in almost every field of physics. The same can not be said of GR. Remember that something like 80% of alll physicists work in solid-state physics or one of its subfields; and that the vast majority are experimentalists. Theoretical cosmology is a tiny field. |
| Jul20-12, 11:52 AM | #43 |
I also recommend Hartle as a starting point in learning GR; that is if you're an undergrad or wish to start learning the theory without learning the full-fledged diff geo behind it first. I thought it was a great book, very intuitive and easy to follow. Personally, I took a GR course as a junior in college and then a Cosmology course as a senior. I believe this is just the right time to start. I plan to take further units in grad school. GR is a beautiful theory and differential geometry alone makes it quite interesting. If you have time though, I recommend learning some diff geo first. It is also quite a beautiful field of mathematics.
| Jul20-12, 04:39 PM | #44 |
Mentor
Concrete example: Which knowledge do you need for a master thesis in experimental particle physics at the LHC? You should know which particles you study, and the relevant decay channels - the basic part (which you learn in courses) can be learned in 10 minutes, a feeling for those things needs practice. You need some basic concepts of special relativity, but probably not in calculations. You need an idea how your particles (or their decay products) behave in the detector - this is very specific, and probably not part of usual courses. |
| Jul20-12, 09:35 PM | #45 |
| Jul21-12, 01:07 PM | #46 |
Can we say that Hartle is soft of "Walter Lewin" in GR?
| Jul22-12, 11:15 PM | #47 |
There are people that specialize on applying GR to cosmology, but that's a small subfield of a small subfield. What most people who are GR specialists do is to try to reduce the equations so that "mere mortals" can use it. You have people writing pages and pages of tensor equations and the punchline is that under conditions X, Y, and Z, you probably can get away with just using Newtonian physics. |
| New Reply |
| Thread Tools | |
Similar Threads for: In what year do you learn GR?
| 15 Year old wishing to self-learn physics and calculus | Science Textbook Discussion | 4 | ||
| Too early to learn Lagrangians as a first year? | Classical Physics | 5 | ||
| I have no grades. I want to learn physics? am I too late at 18 to learn now? | Academic Guidance | 17 | ||
| Advise me how to learn Third year quantum Mechanics | Academic Guidance | 12 | ||
| What to learn in classical mechanics?How to learn it well? | Classical Physics | 0 | ||
