| New Reply |
How does the AC method of factoring quadratics work? |
Share Thread | Thread Tools |
| Jul18-12, 03:12 PM | #1 |
Lets assume you're given
[itex]{ 3x }^{ 2 }+8x-11[/itex] And you want to factor it. With the AC method you multiple 3 and -11 giving you -33. Then you find the factors of -33 that add up to 8. 11 and -3, in this case. Then you rewrite the quadratic as [itex]{ 3x }^{ 2 }-3x+11x-11[/itex] From there, you factor each part independently giving: 3x(x-1)+11(x-1) And finally, factor out (x-1) to get: (3x+11)(x-1). However, I do not have any understanding as to how this works. Thanks |
| Jul18-12, 03:24 PM | #2 |
Here's my attempt at trying to prove this.
The general form of a quadratic is [itex]{ Ax }^{ 2 }+Bx+C[/itex] When factored, you arrive at (px+m)(qx+n) If you work backwards and distribute the factored form you get: 1) [itex]pq{ (x) }^{ 2 } + pn(x) + qm(x) + mn[/itex] 2) [itex]pq{ (x) }^{ 2 } + (pn+qm)x + mn[/itex] You know that if you get back to step 1 then you can successfully factor. However, to do that, you need to split the combined sum of pn + qm back into the two separate addends. In the AC method, you multiple A and C and find the factors of the product adding up to B. In this case, you would multiply pq and mn getting pqmn. So you would find the factors of pqmn adding up (pn + qm). As a result, you would need to get pn and qm. Intuitively, it makes sense, but is there a mathematical proof for this? |
| Jul18-12, 03:44 PM | #3 |
| Jul18-12, 03:51 PM | #4 |
Is there a mathematical proof of my last statement though?
| Jul18-12, 04:03 PM | #5 |
Recognitions:
You want ##(pq)x^2 + (pn+qm)x + (mn) = Ax^2 + Bx + C## for every possible value of x. The only way to do that is when the coefficients of each power of x are the same. In other words ##pq = A##, ##pn+qm = B##, and ##mn = C##. The reason it works is because ##(pq)(mn) = AC## and also ##(pn)(qm) = AC##. So you find two factors of AC that add up to B, and then ##(pq)x^2 + (pn)x +(qm)x + (mn)## ## = px(qx + n) + m(qx + n)## ##= (px + m)(qx + n)##. |
| Jul18-12, 04:07 PM | #6 |
A*C = pqmn. B = pn+qm pq*x^2 + pn*x + qm*x + mn = (pq*x^2 + pn*x) + (qm*x + mn) = p*x(q*x + n) + m*(q*x + n) Now factor the q*x + n and get = (p*x + m)(q*x + n) Edit: I know remember this was tough for me to see when I first saw it. Let (q*x + n) = Z then p*x(q*x + n) + m*(q*x + n) becomes p*x*Z + m*Z Now it is easier to see why you can factor because the above equation becomes Z*(p*x + m) Now substitute back in (q*x + n) for Z... |
| Jul18-12, 04:20 PM | #7 |
| Jul18-12, 06:33 PM | #8 |
I think it to be a variation of this method
[tex]\begin{array}{l} {\rm{sum }}\;{\rm{of}}\;{\rm{ roots = - }}\frac{{{\rm{coefficient}}\;{\rm{ of}}\;{\rm{ x}}}}{{{\rm{coefficient }}\;{\rm{of}}\;{\rm{ }}{{\rm{x}}^{\rm{2}}}}} \\ {\rm{product }}\;{\rm{of}}\;{\rm{ roots = }}\frac{{{\rm{constant}}\;{\rm{ term}}}}{{{\rm{coefficient }}\;{\rm{of }}\;{{\rm{x}}^{\rm{2}}}}} \\ \end{array}[/tex] |
| Jul18-12, 11:53 PM | #9 |
Ooh! That seems to explain it quite well.
| New Reply |
| Thread Tools | |
Similar Threads for: How does the AC method of factoring quadratics work?
| Factoring question - generalized factoring in integers | Linear & Abstract Algebra | 0 | ||
| How exactly does the shooting method work? | General Math | 3 | ||
| Factoring a polynomial where factor theorem doesn't work | Calculus & Beyond Homework | 2 | ||
| Factoring quadratics | Precalculus Mathematics Homework | 9 | ||
| work energy method and impulse momentum method | Classical Physics | 1 | ||
