| New Reply |
Geometric difference between a homotopy equivalance and a homeomorphism |
Share Thread | Thread Tools |
| Jul22-12, 09:02 AM | #18 |
| Jul22-12, 09:12 AM | #19 |
| Jul22-12, 10:10 AM | #20 |
Recognitions:
Also suppose you take a high dimensional lattice, say a 95 dimensional lattice (free abelian group). On the universal covering space of this manifold, this huge lattice must act on a simply connected 4 manifold. That would be interesting to see. Do you just add 95 copies of S^1xS^3 to the 4 sphere with 190 open balls removed? |
| Jul22-12, 01:49 PM | #21 |
Recognitions:
I thought the example I gave you was the simplest possible, i.e. take as fundamental group the zero group, then there are already infinitely many 4 manifolds having that fundamental group, namely all smooth surfaces in CP^3. Once you have that it should be easy to construct infinitely many with any fundamental group, maybe by taking connected sums.
| Jul22-12, 02:12 PM | #22 |
Recognitions:
To show how weird things can get in 4-D without strong conditions, see e.g: http://www.intlpress.com/JDG/archive/1994/39-3-491.pdf |
| Jul22-12, 04:31 PM | #23 |
Recognitions:
on these same lines I remember reading that Morse functions can be used to show that every smooth compact manifold without boundary is homotopy equivalent to a CW complex.
Why is this? |
| Jul22-12, 04:56 PM | #24 |
Recognitions:
Here is a nice article on obstructions to finding a smooth complex projective algebraic variety with given fundamental group. For example the integers do not occur, nor does any free group on n generators, nor does the fundamental group of the klein bottle.
http://library.msri.org/books/Book28/files/arapura.pdf |
| Jul22-12, 05:04 PM | #25 |
Recognitions:
Layman's version: a morse function with one min and one max say on a sphere, says you can construct the sphere up to homotopy by starting from a point (for the min) and adding one disc (for the max). A torus with a morse function with one min, one max, and two flex points, says it has the homotopy type of a point (the min) with a circle added (first flex), then another circle (second flex), then a disc (max). in general, the fundamental theorem of differential equation says that between consecutive critical points, the manifold looks like a cylinder was added, so no change in homotopy (the gradient flow sweeps out the cylinder). I.e. the homotopy type is determined by the critical points. So if you have a morse function with a finite number of critical points, you get the homotopy type of a finite cell complex, and in fact the index of the critical point tells you the dimension of the cell to add. |
| Jul22-12, 05:40 PM | #26 |
Recognitions:
note that even an exotic sphere has a morse function with just two critical points. so when you attach that disc you cannot always attach it differentiably in the usual way. In fact this is apparently how one produces exotic spheres. you produce a manifold that is not an ordinary smooth sphere somehow, but that does have a morse function with only two critical points. then it is homeomorphic to a sphere.
| Jul22-12, 09:15 PM | #27 |
Thanks for your examples
| Jul22-12, 10:03 PM | #28 |
Recognitions:
| Jul22-12, 10:59 PM | #29 |
Recognitions:
So the Eilenberg-McLane spaces cannot be made into varieties? Are these E-M spaces all CW-complexes spaces? manifolds? I mean, I know the trivial examples from, e.g., Wikipedia, on S^1 being a K(Z,1), etc., but I wonder if there are more general results. |
| Jul23-12, 08:53 AM | #30 |
Recognitions:
So all Riemann surfaces except the sphere I guess. all flat Riemannian manifolds such as tori and the Kelin bottle. For finite groups, the EM's are probably all infinite dimensional CW complexes e.g the classifying space for Z/2Z is the infinite real projective space. |
| Jul23-12, 11:45 AM | #31 |
Recognitions:
Lavinia, have you read the classical reference, Milnor's Morse Theory? This is Thm. 3.5 proved in roughly the first 24 pages. He proves that the region on the manifold "below" c+e where c is a critical value, has the homotopy type of the region below c-e with the attachment of a single cell determined by the index of the critical point with value c.
The passage from local to global you ask about may be Lemma 3.7. In it he proves that a homotopy equivalence between two spaces extends to one between the spaces obtained from them by attaching a cell. He makes use of deformation retractions and ultimately uses Whitehead's theorem that a map is a homotopy equivalence if it induces isomorphism on homotopy groups, at least for spaces dominated by CW complexes. |
| Jul23-12, 04:26 PM | #32 |
To do this in the case of manifolds, you can do something similar. You can think of a handle as a thickened up cell. If you want to build an n-manifold, you have to fatten up any k-cells you want to add, so that they are n-dimensional, so you cross them with an n-k-disk. That is a handle. Attaching maps get a little bit more complicated with handles than with CW complex because you need a framing of the core to figure out how to glue the thickened handle on. You won't run into any trouble getting any free group. Start with a 0-handle, which is a thickened 0-cell. Then, attach 1-handles to the boundary, one for each generator. Then, you want to add the 2-handles to kill the relations, as before. I guess you run into trouble here if you have a 3-manifold because the attaching spheres in that case are 1-dimensional and you trying to glue them along the boundary of the 3-manifold, which is a surface, so you don't have enough room to make it an embedding. I think that's the only problem you run into. So, this seems to work for 4-dimensions or higher. What you have at this point is a 4-manifold with boundary. I think you could take the dual handle-decomposition of the manifold and glue it back to itself, this time thinking of the handles as 3-handles and 4-handles. Just as adding a 3-cell will not touch the fundamental group (cellular approximation theorem), a 3-handle will not touch it. Same for 4-handles. Then, connect sum as many simply-connected guys as you want. |
| Jul23-12, 04:54 PM | #33 |
The idea is to look a Morse function on a cobordism with only one critical point, since you can reduce it to that case, by tweaking the Morse function slightly so that none of the critical points are at the same level, and then cutting everything out except one critical point at a time. What you get is a handle of index equal to the index of the critical point (which is the number of minus signs you get when you diagonalize the Hessian or the dimension of the stable manifold when you flow along a gradient-like vector field). You could also appeal to Whitehead's theorem that smooth manifolds admit a triangulation. I think the idea there is that a smooth manifold admits a local triangulation because it looks locally like R^n, which has an obvious triangulation. Then, somehow, I think you can subdivide enough so that you can patch together all the triangulations. Something like that. I don't know exactly how it goes. |
| Jul23-12, 05:07 PM | #34 |
| New Reply |
| Thread Tools | |
Similar Threads for: Geometric difference between a homotopy equivalance and a homeomorphism
| Find the equivalance of AB and BC | Linear & Abstract Algebra | 1 | ||
| Homotopy Analysis Method (or Homotopy Perturbation Method)?? | Differential Equations | 3 | ||
| Distinction between this geometric example of a Diffeomorphism & a Homeomorphism | Differential Geometry | 1 | ||
| Any proof about the equivalance of between theories of R^4 x M and R^10? | Beyond the Standard Model | 1 | ||
| Thematic Program on Geometric Applications of Homotopy Theory | General Physics | 0 | ||
