Short dipole radiation resistance - do you have experimental results?
The discussion revolves around the radiation resistance of short dipoles, specifically comparing different formulas for calculating this resistance and seeking experimental results. Participants explore theoretical derivations, assumptions about current distribution, and practical implications for antenna design.
  • Experimental/applied
  • Some participants present two different formulas for short dipole radiation resistance: one suggesting 200*(l^2/λ^2) Ω and the other 800*(l^2/λ^2) Ω, questioning which is correct.
  • One participant notes that the difference factor of 4 between the two formulas may arise from different definitions of dipole length used in their derivations.
  • Another participant discusses the assumptions behind the Hertzian dipole model, stating that it assumes constant current across the antenna, which is not realistic, and suggests that a more accurate model would consider a linear current distribution.
  • Concerns are raised about the validity of using the Lorentz gauge for deriving radiation resistance, with one participant asserting it is not physically justified.
  • Experimental results from a simulator (EZNEC) are shared, showing input impedance values for a dipole, but questions arise regarding the simulator's calculation methods and their alignment with theoretical formulas.
  • One participant expresses interest in measuring radiation resistance experimentally and asks for specific frequency and antenna dimensions to assist in this effort.
Participants express differing views on the validity of the formulas for radiation resistance and the assumptions behind them. There is no consensus on which formula is correct or on the appropriateness of the theoretical models discussed.
Limitations include unresolved assumptions regarding current distribution and the physical justification of the Lorentz gauge. The discussion also highlights the complexity of accurately modeling radiation resistance in practical applications.
This discussion may be of interest to those involved in antenna design, electromagnetic theory, and experimental physics, particularly in the context of short dipole antennas and their radiation characteristics.
htg
I have seen two formulas for a short dipole radiation resistance - according to one it is about 200*(l^2/λ^2) Ω, according to the second about 800*(l^2/λ^2) Ω.
Which of these is correct, if any? (Let us consider a resonant short dipole, connected to proper inductance).
In particular, I would like to know Rrad for l = 0.1*λ.
My Stutzman & Thiele antenna book derives the 2nd one of the equations you list. Where have you seen the first one derived?
Actually, the difference factor of 4 is suspicious. Perhaps the length of the dipole is defined differently in the two deriviations, with one using the length of an element, and the other using the length of the overall dipole...
Yep, that would be it berkeman. In the "usual" formula [itex]R = \frac{\pi}{6} Z_o (L/\lambda)^2[/itex], the length "L" is the overall length of the dipole. So if we wanted to use the length of an individual element we would have to multiply by four.
I read about existence of derivation of a formula for Rrad by using Lorentz gauge.
Such a derivation would be incorrect (Lorentz gauge is not physically justified, it is only a mathematically convenient assumption of cancellation of certain quantities).
So, does anybody have experimental results regarding Rrad of a short dipole?
The difference is in what assumption is made about the current distribution on the antenna conductors.
Radiation resistance of the Hertzian dipole is 790(l/λ)^2. The Hertzian dipole assumes constant current across antenna axis. In other words current at the tips of the dipole are equal to the current everywhere else. This is obviously not possible unless it is a "top hat" type.
Another popular assumption, which is a little more realistic, is that current vary linearly with distance away from center, with zero current at tips. Radiation resistance of this turns out to be exactly 1/4 of Hertzian.
Of course this is not the actual current distribution, but an approximation that makes derivation of closed form solution feasible.
There are other assumptions that go into these formulas:
No ground plane.
Infinitely thin wire.
If you really need the radiation resistance with accuracy it is better to model it.
How can the Larmor formula be derived?
The Larmor formula involves radiation from a point charge. The dipole formulas previously discussed have to do with radiation from a string of infinitesimal current sources.
htg, what exactly is your goal. Are you trying to design an actual antenna?
Hey, thanks for that, EMI Guy! Interesting.
It looks like the Hertzian dipole model is proper for my problem. I am trying to calculate how much power will a short dipole reradiate if an EM wave of certain intensity reaches it.
Is there anybody who has experimental results regarding Rrad of a short dipole? In particular I am interested in the case length = 0.1*lambda.
You can get the input impedance of a dipole from a simulator.
I use EZNEC.
Here are some results...
Frequency 10 MHz. Wavelength 30 meters. Dipole length 3 meters. Dipole wire diameter 1 cm.
So, near enough to 0.1 wavelength long.
Input impedance at the center = 2 - J 1773
So, that is 2 ohms resistive in series with about 9 pF.
The 2 ohms would be mainly the radiation resistance as the wire is actually a piece of 1 cm (0.4 inch) pipe. Increasing the diameter of the wire to 5 cm (2 inches) reduced the input impedance to 1.9 - J1140.
That is 1.9 ohms in series with about 14 pF.
If you wanted to use this as an antenna, you would need to put an inductor of 18 μH in series with the feedpoint to cancel out the capacitance, and also drive an impedance of about 2 ohms.
Not easy to do without a lot of losses.
I use EZNEC.
...near enough to 0.1 wavelength long.
Thanks for the results from your simulator, but:
How does the simulator calculate it? I am asking, because theoretical derivation of the widely known formulas for Rrad is based on Lorentz gauge, which has no physical justification. So it would be a little strange if these formulas agreed with experiments.
You did ask for practical results.
I can't help you with that, but you could contact the guru of antenna theory, Roy Lewallan W7EL, who is the author of that simulator. He gives this email address in the simulator:
I can send it to your private mail if you like
But don't go in claiming that standard formulas are wrong. You won't get a reply if you do that.
The simulator does not give radiation resistance directly, but it can be estimated from the input impedance of a low loss antenna.
If you are interested, you could download a copy of the free demo version of this program from
http://www.eznec.com/demoinfo.htm
This program is nothing much to look at but it gives very accurate results and is easy to use.
I do know that it works on a system of segments where the antenna is split up into short segments and the center of each is regarded as a point source.
htg said:
...How does the simulator calculate it?
Go to Wikipedia page for "Numerical Electromagnetics Code". You will find basic info there.
Follow link to the NEC2 unofficial home page (http://www.nec2.org) and find NEC Program Description - Theory.
Are you trying to design an antenna here or dispute the mathematics used to derive textbook formulas? If textbook formulas are incorrect it is due to expedient simplifying assumptions, not flawed underlying physics (as far as I know).
The majority NEC's computational effort is in determining the currents along the conductors (magnitude and phase). Given this current distribution, computing the far fields is a relatively simple back-end part of the process. The textbook formulas assume a very simplified current distribution.
@htg -- I can probably measure this for you after hours at work. What frequency are you interested in, and what are the physical dimensions of your antenna? What is the application?
@berkeman - what I acually want to know is the power which is reradiated by a resonant, short-circuited short dipole when a wave of given intensity P/S reaches the short dipole - say at 150 MHz, length=0.2*λ = 0.4m. So the radiation resistance that I need will perhaps correspond to uniformly distributed current in the short dipole. Perhaps you can achieve similar result by using a short dipole with disks or spheres at the outer ends, so that the extra capacitance will make the current more uniformly distributed.
If you can measure Rrad of such short dipole fed at the center, say with disks at the outer ends, it will give me a pretty good idea of what to expect.
According to what I know, the capacitance of a single disk is given by C = 8*ε0*r, where r is the radius of the disk.
I don't think an electrically short reflector will be very effective. Is it supposed to be an element in a multi-element (but electrically short) array, like a Yagi?
I consider using such an array. But for the beginning I want to know what to expect if I use a single resonant, short-circuited dipole.
