Formula for magnetic field of solenoid
The magnetic field of a solenoid on its axis can be calculated using the formula B = kμ₀ In/L, where B is the magnetic field, I is the current, k is the permeability constant, n is the number of turns, and L is the length of the solenoid. For points at a distance from the center, the Biot-Savart law must be applied, resulting in B = (μ R² n I) / (2 d²), where R is the radius of the solenoid and d is the distance from the center. Additionally, to calculate the force on a material point within the solenoid, the user needs to consider the magnetic field strength and the magnetic moment of the material.
  • Understanding of electromagnetic theory
  • Familiarity with the Biot-Savart law
  • Knowledge of magnetic field calculations
  • Basic principles of magnetic forces on materials
  • Study the Biot-Savart law in detail for complex geometries
  • Learn about magnetic field strength calculations in solenoids
  • Explore the concept of magnetic moment and its relation to force
  • Investigate numerical methods for integrating magnetic fields from current loops
Students and professionals in physics, electrical engineering, and materials science who are interested in understanding the magnetic fields generated by solenoids and their effects on nearby materials.
Gosuto Inu
Hi!
I need formula for magnetic field of solenoid on axis of solenoid in some distance from center.Also I need something about interaction magnetic field on material point(interaction solenoid on material point).I want to know force that infuence on material point. Thx in advance and sry for my bad english :-p
Gosuto Inu said:
Hi!
The field at the center is:
[tex]B = k\mu_0 In/L[/tex]
where B = magnetic field; I = current; k = permeability constant [itex]\mu/\mu_0[/itex]; and n = number of turns; L = length of solenoid.
To find the B at a distance from the center you have to apply the Biot-Savart law which is pretty complicated for a solenoid. You have to integrate the contributions from all the current elements of each loop. At a large distance from the center (large compared to the length and diameter of the solenoid) it would be something like:
[tex]B = \frac{\mu R^2nI}{2d^2}[/tex]
where R is the radius of the solenoid; d is the distance away; n is no of turns;
AM
  • · Replies 17 ·
  • · Replies 21 ·
