Object's Velocity: Up, Highest, Down
  • Thread starter Thread starter Gilly1998
    Velocity
The discussion revolves around the concepts of velocity and acceleration of an object thrown vertically. Participants explore the direction of velocity during the object's ascent, at its peak, and during its descent, while also addressing the constancy of acceleration due to gravity.
  • Participants discuss the signs of velocity as the object moves up, reaches its highest point, and falls back down. Questions arise regarding the velocity when the object returns to the thrower's hand, and the implications of defining upward as positive.
There is an active exchange of ideas regarding the definitions of velocity and acceleration. Some participants provide clarifications on the signs of velocity based on direction, while others question the assumptions about the reference frame used for defining positive and negative values.
Some participants express their inexperience with physics, indicating a learning environment. The discussion includes varying interpretations of velocity signs based on chosen coordinate systems.
Gilly1998
Suppose I throw an object up in the air. What is the direction of velocity on the way up, at its highest point and on the way down. Accelartion is constant, correct?
Velocity is just speed but with a direction. As the object goes up, the velocity will be in the same direction as the object travels (up, which is +ve). At the highest point, the object is not moving. And on the way down, the object is moving down, so you can figure the velocity, right?
As for acceleration, it is ALWAYS equal to [tex]-9.81\frac{m}{s^2}[/tex]
Sorry this is childs play but I am new to physics. So velocity is positive as it goes upward, when it reaches the top it becomes zero, and as it falls velocity is negative.
Suppose i throw an object upward at 5m/s when the object returns to my hand its velocity is still 5m/s, correct? Or wait -5m/s?
Yes,once u chose an axis for the vertical coordinate,then u have various signs for the components of the vectors,in particular for "v"...
So it's -5ms^{-1}.
Daniel.
Anytime an object is moving upwards, its velocity is +ve. Anytime it's moving downwards, its velocity is -ve. If it's not moving, its velocity is zero. So when the object returns to you hand, its velocity is -5m/s. (Same speed as when it left your hand, but opposite direction). Hope you get it now... :smile:
This is only true if you define the upwards direction as positive.
Yes, Sirus. Everything is relative. But usually, when you are asked for the velocity of an object traveling downwards, you put down a negative velocity as the answer. :devil:
wow, that's a fast response. I got it now. Thanks everyone :biggrin:
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 17 ·
