New Reply
Calculating the charge distribution on the surface of an assymetric conductor
Share Thread
Jul25-12, 11:49 PM   #1
How do I calculate the charge distribution on the surface of any asymmetric closed conducting surface? Is it possible for me to calculate the surface charge density 'σ' as a function of '[itex]\bar{r}[/itex]' the position vector in a spherical co-ordinate system in space, provided I know that the conductor has been qiven a net charge 'Q' and the equation of the conductor in space is ((x/a)^2)+((y/b)^2)+((z/c)^2)=1...
2. Relevant equations
3. The attempt at a solution
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jul26-12, 02:16 AM   #2
For any conducting surface you will have to resort to an approximation.
In brief: use a numerical method to establish the Electric field for the system. Use that E field result to establish surface charge distribution.
Jul26-12, 01:41 PM   #3
But how do I calculate [itex]\bar{E}[/itex] if I don't know my σ? It's like the chicken egg problem except that it's not what comes first that matters, but I need one to know the other. All I know unfortunately is the shape of the conductor and the total charge Q which according to the uniqueness theorum has a unique way of settling on the surface in the abscence of any external electric field...
Jul26-12, 02:21 PM   #4
you don't need to know anything about the charge. Field lines are normal to a conducting surface and themselves normal to equipotentials. This means that you can set up a grid with random starting values for potential and by recalculating each value in turn end up closer to the correct solution.
a quick google gave this http://www.physics.hku.hk/~phys3231/...%20in%202D.pdf The 3d process is very similar.
Also http://www.ece.msstate.edu/~donohoe/...techniques.pdf you need the last few pages.
The procedure looks hard but really isn't: Though it is a long time since I last did one!
Jul26-12, 04:29 PM   #5
Recognitions:
Homework Helper Homework Help
Just solve Laplace's equation for the potential. You know that the potential on the surface is a constant (which you may as well set to zero) and that the potential at large distances should look like that of a point charge, so you have your 2 boundary conditions. From the potential, you can determine the charge density.
New Reply
Similar discussions for: Calculating the charge distribution on the surface of an assymetric conductor
Thread Forum Replies
Non uniform charge distribution on conductor surface General Physics 2
Conductor/Image Charge, Volume Charge Distribution Advanced Physics Homework 1
distribution of charge within a CONDUCTOR General Physics 8
charge distribution on a conductor. Introductory Physics Homework 0
Surface charge induced in conductor by point charge Introductory Physics Homework 17
