The proof given by the book doesn't seem to work.
  • Context: Graduate
  • Thread starter Thread starter limitkiller
    Set
The discussion revolves around a mathematical proof concerning the division of the numbers 1 through 5n into two disjoint sets, with the goal of demonstrating that these sets contain at least n pairs (x, y) where x > y and x - y is also an element of the set containing the pair. Participants are analyzing the validity of a proof provided in a book and exploring alternative approaches to establish the claim.
  • Some participants argue that the proof is flawed because the same pair can satisfy multiple values of k, leading to potential overlaps that are not adequately addressed.
  • Others propose that the proof could be salvageable by ensuring that distinct good pairs exist among the sets, particularly focusing on the structure of the sets S_k and S_{2k}.
  • A participant suggests that if S_k is split correctly, it could guarantee the existence of another good pair, thus supporting the claim.
  • There is a discussion about the nature of overlaps, with some participants questioning whether (2m, 4m) is the only pair that can overlap and suggesting that other instances should be considered.
  • Induction is mentioned as a method to prove the statement, with participants discussing the base case and the implications for n+1, particularly in terms of odd and even cases.
  • Some participants express uncertainty about the proof's validity and acknowledge potential mistakes in their reasoning, indicating a need for further investigation.
Participants do not reach a consensus on the validity of the original proof. There are competing views on whether the proof can be salvaged and how overlaps should be handled. The discussion remains unresolved with multiple perspectives on the matter.
Participants note limitations in the original proof, particularly regarding the treatment of overlaps and the conditions under which pairs can be considered good. There is also mention of the need to clarify definitions and assumptions related to the sets involved.
limitkiller
"The numbers 1, 2, . . . , 5n are divided into two disjoint sets. Prove that these
sets contain at least n pairs (x, y), x > y, such that the number x -y is also an
element of the set which contains the pair."
proof:"Suppose, for the sake of contradiction, that there are two sets A and B such
that AU B = {I, 2, ... , 5n}, An B = 0 and the sets contain together less than n pairs (x, y), x > y, with the desired property.
Let k be a given number, k = 1, n. If k and 2k are in the same set - A or B -
the same can be said about the difference 2k - k = k. The same argument is applied
for 4k and 2k. Consider the case when k and 4k are elements of A and 2k is an
element of B. If 3k is an element of A, then 4k - 3k = k E A, so let 3k E B. Now if
5k E A, then 5k - 4k = k E A and if 5k E B, then 5k - 3k = 2k E B; so among the
numbers k, 2k, 3k, 4k, 5k there is at least a pair with the desired property. Because
k = 1 , 2, ... , n, it follows that there are at least n pairs with the desired property. (Dorin Andrica, Revista Matematica Timi§oara (RMT) , No. 2(1978), pp. 75,
Problem 3698)"(E means belongs to)
Does anybody know of a proof?
Mathematics news on Phys.org
I agree, the proof is broken. The same pair can satisfy the 5 multiples of more than one k, e.g. (2, 4) is in both (1, 2, 3, 4, 5) and (2, 4, 6, 8, 10).
It isn't even clear whether the claim is that the pairs are disjoint. E.g. would 5-1=4 and 5-2=3 constitute 2 pairs? I guess so.
The attempted proof is only scratching the surface for the possible combinations, so I expect the claim is true. Doesn't look easy though.
Hmm, I think the proof is salvageable. I will call the pairs with the property that the difference appears in its set a good pair. Basically, the only times you can have those "overlaps" is when 2k and 4k of {k,2k,...,5k} are in the same set. However, if we can guarantee that there must be another distinct good pair (by distinct, I mean BOTH numbers are different) among either {k,...,5k} or {2k,4k,...,10k}. From here on, I will let S_k = {k,2k,3k,4k,5k}.
So if S_k is split such that there is another good pair, then we are done.
Otherwise, (2k,4k) is the only good pair contributed by S_k, and so it must be split like: (2k,4k) and (k,3k,5k); (2k,3k,4k) and (1k,5k); or (2k,4k,5k) and (1k,3k).
Now let us try to place 6k, 8k, and 10k into those two sets. If 6k or 8k is placed with (2k,4k), we are done. Otherwise, 6k and 8k must go in the other set with 1k. If 5k is with 1k or 3k is with 1k, then we are done, since 6k - 5k = k and 6k - 3k = 3k. Thus, no matter what, there must be another good pair among S_k U S_{2k}.
Now we proceed by induction. The statement is clearly true for n = 1. Assume it is true for some n >= 1, and consider the case for n+1. If n+1 is odd, then we are done (S_{n+1} contributes at least one good pair, and it cannot overlap with any other previously found pair since n+1 is odd).
If n+1 is even, let m = (n+1)/2. If S_{n+1} contributes a good pair that is not (2m,4m) = (n+1,2(n+1)), then we are done. Otherwise, say that S_{n+1} can only contribute (2m,4m).
Then consider the good pair S_m contributes. By above, S_m must contribute another good pair that is not (2m,4m). If m is not even or that other good pair is not (m,2m), then we are done. Otherwise, we may repeat the subprocess again, and this process must terminate since m can be divisible by only a finite power of 2.
This completes the proof.
Sorry if the proof is a bit messy and full of bad notation. But I think this fixes the hole in the proof.
Hmm, I think the proof is salvageable. I will call the pairs with the property that the difference appears in its set a good pair. Basically, the only times you can have those "overlaps" is when 2k and 4k of {k,2k,...,5k} are in the same set. However, if we can guarantee that there must be another distinct good pair (by distinct, I mean BOTH numbers are different) among either {k,...,5k} or {2k,4k,...,10k}, then we should be fine. From here on, I will let S_k = {k,2k,3k,4k,5k}.
So if S_k is split such that there is another good pair besides (2k,4k), then we are done.
Thanks for the replies.
Yes,this is what I meant.
Why? let's say we had {k,2k,...,5k,6k,..nk}.Which numbers can overlap now?
it ignores that {2,4,6,8,10} and {4,8,12,16,20} have 4 and 8 in common,doesnt it? (it only investigates k = n and n+1 but we can have other instances)
I think you should investigate n and 2n rather than n and n+1.(I do not have a proof but overlappings seem to be only in n and 2n)
The proof seems to be correct but I can't understand why (2m,4m) is the only pair which can overlap.
[EDIT] Now that I look at it more carefully, I think there is a BIG hole in my proof >< My mistake and apologies. I guess doing this at 3 in the morning is not the best way to go. I'll see if I can salvage this again.
Given S_k and S_{2k}, the only good pair those two can be possibly offered by both is (2k,4k), since S_k n S_{2k} = {2k,4k}. So (2k,4k) can be the only overlapping good pair between S_k and S_{2k}. If S_m and S_n are such that m =/= 2n and n =/=2m, then the two sets cannot have overlapping pairs.
who_ said:
[EDIT]
Is it though?
I mean how do we know that s_k and s_2k are the only good pairs?
Okay, I think I have a fix. Let my make my proof more rigorous.
Okay, oh man. The proof I have is really messy and involves a lot of case work. The proof is I have is 2 pages long, so I'm not going to bother to post it up, unless you are a masochist and would still like the proof. I'll see if I can find a better proof.
What I mean is that if there were a good pair that came from both S_k and S_{2k}, then that pair would have to be (2k,4k). There could be other pairs contributed by S_k and S_{2k}, but those cannot appear both in S_k and S_{2k}.
Okay, oh man. The proof I have is really messy and involves a lot of case work. The proof is I have is 2 pages long, so I'm not going to bother to post it up, unless you are a masochist and would still like the proof. :) I'll see if I can find a better proof.
I most certainly am.
If the proof works I won't mind reading it.
does your proof use the fact that k and k+1 are coprimes and if a good pair is in the form s_k and s_k+1 ,k should be less than 5?and then extending it and checking some special cases?
if not please give a brief version of your proof.for example remove parts where you think are easy to understand and/or are obvious.
who_ said:
What I mean is that if there were a good pair that came from both S_k and S_{2k}, .
What if there is a good pair that is ,lets say,in form of s_k and s_k+4 and k is not 4?
That is the basic concept of the proof. I am still working out a few details, but I am pretty sure that this trail of thought will give a correct proof.
[EDIT] Now I am becoming more doubtful it will work. Sigh - I am sorry for all this confusion.
I am not sure what you are asking. S_k is a set.
I am not sure what you are asking. S_k is a set.[/QUOTE]
isnt s_k={k,2k,3k,4k,5k}?
Yes, it is.
so what I am saying is you already assumed that overlappings can only occur in s_k and s_2k.
It seems to be true ,but I can't understand why...
Right. Let's say that S_k and S_m have overlapping pairs, and assume that k < m. Then if the pair is (a,b), with a < b, a = pk and b = qk for some 1 <= p < q <= 5.
Since (a,b) is also from S_m, we must have b >= 2m, so that m <= b/2 <= 5k/2, and must we have that there exists 1 <= p', q' <= 5 such that p'm = pk and q'm = qk.
If p = 2 and q = 4, then we can choose p' = 1, q' = 2, and m = 2k. Otherwise, p and q must be relatively prime, so that m cannot be greater than k (can you see why?).
Thus, an overlap only occurs only with sets S_k and S_{2k}, and that overlap must be (2k,4k).
Another observation I am trying to use is the following: if a pair (a,b) with a > b is good and a =/= 2b, then (a,a-b) is also good. Might help : /
Thanks,now I get it...(actually a I didnt get why b/2 <= 5k/2 ,but that's OK)
So what is the problem now?isnt the proof complete?
b/2 <= 5k/2 because b is from {k,2k,3k,4k,5k}, so that b <= 5k. It turned out to be unnecessary though :P
Nope. It still has holes that can't be filled. I might be looking in the completely wrong direction, but am trying to correct my proof, or find another proof. I have a feeling though that this shouldn't be too hard. Hmmm ><
would you show some?
  • · Replies 0 ·
  • · Replies 17 ·
