Reaction at roller connecting two cantilever beams
The discussion focuses on calculating the reaction at roller E connecting two cantilever beams AB and DC, given specific material properties and cross-sections. Participants emphasize the importance of using stress relation equations and reaction equations to derive the necessary forces. A key insight is that the deflection at joint E must equal the deflections at points A and C, leading to the equation δe = δab = δdc. Proper application of superposition is crucial for accurately determining deflections at the pin supports.
  • Understanding of cantilever beam theory
  • Familiarity with deflection equations and superposition principles
  • Knowledge of stress relation equations in structural analysis
  • Ability to balance moment equations in static equilibrium
  • Study the principles of cantilever beam deflection and superposition methods
  • Learn how to derive and apply stress relation equations in structural analysis
  • Explore methods for balancing moment equations in static systems
  • Investigate the effects of distributed loads on cantilever beams
Structural engineers, civil engineering students, and anyone involved in analyzing cantilever beam systems will benefit from this discussion.
iqjump123
The problem statement is as stated in the attached image, For a given E and cross section of both beams, I am to find the reaction at roller E that attaches beam AB and DC
There should be stress relation equations and reaction equations. First is to go through the different equations, and then after getting the reaction, the maximum stress at AB will depend directly on the reaction at E - reaction at D.
I was first thinking that I could treat this problem as two separate beams, and after getting the reaction forces at point B and point D, I can relate it with the deflection equation, saying
δe=δab+δdc . But then, how would I express the material properties of e?
I then thought of just listing out the forces -
then it will be Ra-2*5(the distributed force)+Rb+Rd-5+Rc=0, and next will be Re=Rd+Rb. But where will I gain the other 3 equations? Would it come from balancing the moment equations at A, E, and C?
Maybe a step in the right direction will help. thanks!
Your compatability equation δe = δab + δdc is not correct. The deflection of joint e is the same as the deflection of δab and the same as the deflection of δdc, that is, δe = δab =[/color] δdc . Look at each beam separately: the beam ab has the applied load plus the unknown load E at the pin; the beam cd has its applied load and the unknown load E (opposite in direction) at the pin. Set the deflections of each beam equal to solve for E. Be sure to calculate the deflections of the cantilevers at the pin properly using superposition for each.
Jay says "Be sure to calculate the deflections of the cantilevers at the pin properly using superposition for each." Even though these beams are indeterminate propped cantilevers with spring supports at the free ends, formulas for cantilever deflection can be used to solve this.
