| New Reply |
can you use induction on n cases (as opposed to infinity)? |
Share Thread | Thread Tools |
| Jul27-12, 09:19 PM | #1 |
this is probably a dumb question, but i'm doing this proof where i have to show two sets are equal, where each set is a union from 1 to n sets. this is pretty easy to show with induction, i think, but i'm used to using induction when i have an infinite amount of things, so i'm not sure i'm allowed to use induction. any thoughts? specifically, it goes like this: Suppose that A_1, ..., An are Borel sets, that is they belong to ß. Define the following sets: B_1 = A_1, B_n = A_n ∩ (A_1∪ ... ∪ A_n-–1)^c (^c is complement), and let S equal the universal set. Show that U_i=1 to n A_i = U_i=1 to n B_i. 2. Relevant equations 3. The attempt at a solution U_1 to 1 A_i = A_1 = U_1 to 1 B_i = B_1. So we have a base case. So assume it's true for n=k. Then we have that U_i=1 to k A_i = U_i=1 to k B_i. Then we have that U_i to k B_i U B_k+1 = U_i to k A_i U (A_k+1 ∩ (A_1∪ ... ∪ A_k)^c =U_i to k A_i U (A_k+1 ∩ A_1^c ∩ A_2^c...∩A_k^c)... Let A_1^c ∩ A_2^c...∩A_k^c = D, and let U_i to k A_i = E Then we have U_i to k B_i U B_k+1 = E U (A_k+1 ∩ D) = (E U D) ∩ (E U A_k+1) = S ∩ (U_i to k A_i U A_k+1) = U_i=1 to k+1 A_i. god that looks hideous. hopefully it makes sense. any comments would be appreciated. |
| Jul27-12, 10:07 PM | #2 |
Please take out a little of your time to learn LaTeX: http://www.physicsforums.com/showthr...=1#post3977517
Your post is close to unreadable. |
| Jul27-12, 10:12 PM | #3 |
Recognitions:
That is hideous to read. The basic idea is that E U (A_k+1 n E^c)=E U A_k+1. Right? You can certainly use induction on a finite set of premises, no problem with that. It looks ok to me. Cleaning up the presentation certainly wouldn't hurt. Using TeX wouldn't hurt either. But I think you've got one way to do it.
| Jul27-12, 11:01 PM | #4 |
The purpose of induction is to show that if a statement is true for some value k, it has to be true for k+1.
It's up to you how far you want to extend your conclusion, so it's perfectly fine to use it on a finite set. |
| Jul27-12, 11:17 PM | #5 |
alright, sorry i was a bit lazy on the latex, i didn't think it would be that bad originally, and i haven't used latex in a while.
i've attached a pdf. how does that look? |
| Jul27-12, 11:41 PM | #6 |
Recognitions:
| Jul28-12, 12:40 AM | #7 |
I'm not sure where the "finiteness" of your question is. Also, to answer your original question, it is perfectly fine to use induction where the variable you are inducting on has finite range. It is a common technique used in real analysis. In fact, the original definition of induction imposes no restriction that the variable has to have infinite (countably infinite) range.
| Jul28-12, 01:03 AM | #8 |
awesome, thanks you guys.
| New Reply |
| Thread Tools | |
Similar Threads for: can you use induction on n cases (as opposed to infinity)?
| Is probability meaningful in cases of infinity? | Set Theory, Logic, Probability, Statistics | 7 | ||
| Is the principle of mathematical induction unable to prove cases of negative numbers? | General Math | 2 | ||
| Translating a strong induction to test cases if valid or invalid? answers given | Calculus & Beyond Homework | 0 | ||
| Deuterium as opposed to di-proton | High Energy, Nuclear, Particle Physics | 5 | ||
| Watts as opposed to Joules? | Introductory Physics Homework | 2 | ||
