Nonlinear Differential equation
The discussion revolves around a differential equation presented by the original poster, which they initially classify as nonlinear. The equation involves variable coefficients and is expressed as a second-order differential equation. Participants are exploring the nature of the equation and potential solution methods.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Some participants question the classification of the equation as nonlinear, suggesting it is actually a linear equation with variable coefficients. Others discuss the applicability of series solutions and propose substitutions to simplify the equation. There is also mention of the Airy family of functions as a potential solution.
The discussion is active, with participants providing insights into the nature of the equation and exploring different approaches. There is no explicit consensus on the classification of the equation, but some productive lines of reasoning have been shared regarding possible solution methods.
Participants are operating under the assumption that the original poster is seeking alternative methods to solve the equation beyond series solutions, while also clarifying definitions related to linearity in differential equations.
spacetime
Variable co-effiecients Linear Differential equation
[tex]\frac{d^2 y}{dx^2} = c_1y(1-c_2x)[/tex]
any help? Is there a solution besides a series solution?
First, let me point out that that is NOT a non-linear equation! I wondered about that before the "tex" came up since a "series solution" will not work for a non-linear equation.
It is rather, a "linear equation with variable coefficients". I don't see any method other than a series solution which should work nicely.
For future reference,an ODE is said to be NONLINEAR in three possble cases
1.The power of the derivative(s) is not "1".
2.The power of the unknown function is not "1".
3.Cases 1 & 2 at the same time...
Daniel.
try substitude u = 1 - cx,
The solutions are the Airy family of functions in disguise:
Let:
[tex]u=ax+b[/tex]
where "a,b" are constants to be determined.
Then:
[tex]\frac{d^{2}y}{dx^{2}}=a^{2}\frac{d^{2}y}{du^{2}}[/tex]
In order to determine "a,b", we require:
[tex]\frac{c_{1}-c_{1}c_{2}x}{a^{2}}=ax+b=u[/tex]
This yields:
[tex]a=-(c_{1}c_{2})^{\frac{1}{3}},b=(\frac{c_{1}}{c_{2}^{2}})^{\frac{1}{3}}[/tex]
And with these choices:
[tex]\frac{d^{2}y}{du^{2}}=uy[/tex]
This is the Airy differential equation.
The power series solutions(i.e, Airy functions) are well studied.
Daniel.
It' also considered non-linear if the dependent variable is contained in a transcendental function; the non-linear pendulum being the canonical example:
[tex]\frac{d^2\theta}{d t^2} + (g/L)\sin{\theta} = 0[/tex]
You know, when you have a pendulum on a rigid rod and push it so hard it goes round and round.
  • · Replies 28 ·
  • · Replies 32 ·
