Is It Safe to Touch Metal Inside Your Car if a Transmission Line Falls on It?
The discussion revolves around the safety of touching metal inside a car if a transmission line falls on it, exploring the implications of high voltage and the potential for electric shock. Participants consider various scenarios, including the effects of being inside the car versus exiting it, and the role of the car's structure in providing safety.
  • Some participants express concern that even small metal parts, like a seat-adjuster, could pose a risk of electrocution if a transmission line falls on the car.
  • Others suggest that the majority of electricity would flow through the car's outer shell to the ground, but there may still be enough stray current to cause harm if touching metal parts inside the car.
  • There are differing opinions on whether touching plastic would be dangerous, with some asserting it should be safe while others remain cautious.
  • One participant emphasizes the importance of staying inside the car and avoiding contact with metal parts, especially electrical components, unless absolutely necessary.
  • Another participant mentions that the car acts as a Faraday cage, but questions whether all metal parts are electrically connected, suggesting that it may not be entirely reliable for safety.
  • Concerns are raised about the insulating properties of tires and the potential for current to flow through them, with some participants noting that tires may not provide adequate protection against high voltages.
  • Participants discuss the behavior of lightning in relation to cars, noting that while being in a car during a lightning strike is generally considered safe, there are instances where tires have melted or exploded upon contact with lightning.
  • Some participants share anecdotal evidence regarding lightning strikes and their effects, including deafness as a common complaint among victims.
Participants do not reach a consensus on the safety of touching metal inside the car, with multiple competing views on the risks involved and the effectiveness of the car's structure as a protective measure. The discussion remains unresolved regarding the specifics of safety in such scenarios.
Participants highlight limitations in their understanding of the electrical properties involved, including the range of voltages in transmission lines and the behavior of electricity in relation to the car's structure and tires. There is also uncertainty regarding the effectiveness of the car as a Faraday cage.
thetaobums
I mean even something tiny, like the seat-adjuster...would that electrocute you to death?
Is it possible to touch something plastic and still get electrocuted?
Given the very high voltage in transmission lines, and their ability to move a LOT of electrons (current), I'd guess that the fact that MOST of the electricity should flow through the outer shell of the car to the ground would NOT stop their being enough stray current to spark through your body from, say, your hand on the gearshift and your arm next to the door, so yeah I'd say you could get fried, although not like what you would if it was just you the transmission line hit.
I'll be interested to see if other have a more knowledgeable take on the question.
would touching plastic be dangerous too?
First and foremost, stay inside the car. Stepping out could be fatal. If you are forced to get out, and i do mean forced, due to say fire, you've got to jump out clear with both feet without touching the exterior of the car. Not easy. Touching plastic while within the car should be no problem . I'd stay away from touching metal especially if it is an electrical part of the car like a radio. In the extreme example of being forced to exit, you'd probably be ok opening the metal door handle , but this is the last resort.
The body of the car forms somewhat of a Faraday cage. But for that to be true, all metal parts must be electrically connected. If I were in that situation I would not bet my life on it. I would just sit tight until the power lines were turned off and removed. If I must exit then I would do as PhanthomJay described.
You may find this video interesting:
I do not KNOW what would happen, but touching anything unnecessary is NOT safe. There would be no way to tell for example if power was flowing thru tires to the ground or not.
Also, I don't know the range of voltages in transmission lines...but touvhing stuff would NOT be a good way to find out!
Wiki says:
Today, transmission-level voltages are usually considered to be 110 kV and above.
http://en.wikipedia.org/wiki/Electric_power_transmission
and I have read discussions about 345,000 volt transmission lines!
Also, for comparison, about 10 to 15 thousand volts are necessary to jump a spark plug gap..[modern transistor ignitions gor much higher]...so transmission line voltages are certainly capable of jumping open space...especially if ANY ionizing is present...
A 100 kV line can jump about a 1 ft air gap to a grounded object or person. More like 3 or 4 feet at 300 kV. There have been instances where careless crane or dump truck operators have made contact (or come in proximity close enough to draw the arc ) with hi voltage lines. Generally speaking, those who remained inside the vehicle have survived; those who have tried to get out sometimes have not.
I really have to start wearing my glasses. Up until Turtlemeister's post, I thought that the OP asked about if a transmission line fails on a car. I figured that everyone was teasing him, because since when are transmissions electrically charged? :redface:
I've been taught in electrostatics lessons that ALL of the charge is on the outside of a 'faraday cage'...ALL of it, not most of it.
If the car is metal and is connected to the ground I think that is a faraday cage. If it was me i would touch the inside for a bet and I would win.
@Naty... I would hope that current was flowing through tires but is should not if the metal body is connected to the ground.
I think people in aeroplanes do not get a shock when it is hit by lightning.
Also...345,000V transmission lines do not occur 'in discussions'...they are real...some are bigger than this.
If the transmission line falls on your car, the car will become charged - the current will not flow to the ground because of the tyres.
While you're in the car, you're safe to touch any of the metal etc - because there isn't a circuit between you and the ground. If you get out of the car, and while you're getting out if you touch the metal parts of the car (high enough voltage any part will do), a circuit may be made between you and the ground. And the electricity will flow through you. And you will be cooked.
And I've heard...you will smell like a roast chicken.
Lightening strikes are interesting, as it's a much higher voltage and more power - if you're struck by lightening, it will conduct over the warm air just about your skin, so very few people die from lightning strikes. If it went through you, you'd be burned to a cinder.
And in their case, the tires are of absolutely no use.
Tires no use !
Full flaps...that's a tennis court!
Don't get the logic, please explain
A car is not a perfect faraday cage. Half of them are made of cheap plastic. But neither a plastic body nor rubber tires may have the insulating properties to withstand 100 kV. I've seen photos of melted tires from powerline contacts.
In a perfect faraday cage, you can touch the inside of the metal cage if standing within , and be just fine at any voltage. In a car, whether it is grounded or not, I would refrain from touching metal, even if it may not cause harm. Be safe!
Regarding lightning , many have been killed , either by direct hit or more often, from the voltage gradient from a nearby strike to ground. That is why if stuck in the open during a lightning storm and shelter ( or a faraday cage ) is not nearby, you must crouch low and click heels together so that ground currents pass thru your feet and not your heart.
Yes, but. If you're in a car and it's struck by lightning - the arc will just have a few inches to travel to the ground. So, it's pretty safe to be in a car in a lightning storm - but your ears might be ringing. It's interesting how lightning prefers the air over a solid conductor - i think it's the air becoming ionised.
As for lightning striking in the same place twice - there's always a good chance it will. I didn't know the guy, but my father and lots of other people did. A farmer near where I grew up. He was watching a lightning storm out of his bedroom window (they're always fun to watch). He got struck. It burned all the hair off his body, but he was fine otherwise. So...a period later there was another lightning storm...and as he believed the old wives tale, so he went to his bedroom window to watch it - believing he was safe...And of course he was struck again. ...It didn't kill him...but it was the last time he observed lightning storms from his bedroom window...It a site gets struck once, it may have geo/electrical properties that make it likely for a repeat strike.
The CN tower gets struck about 75 times per year. It's something like 25 times for the Empire State building. I don't know what the number is for the Eiffel tower, but I wouldn't want to be leaning against it in a storm.
Emily, I was referring to what Phantom said. I've seen vehicles that were struck, and in several cases the tires exploded and melted. Even in cases where they remain intact, the lightning just jumps the gap between the pumpkin or rims and the ground.
Incidentally, I saw it reported about 40 years ago that the single most common complaint of lightning victims was deafness. The thunder can knock your eardrums half-silly.
interesting stat, thanks. S.O.P. In lightning storms when no options available is to crouch low to the ground on balls of feet with heels clicked together, AND block your ears!
Sounds like a lot of people are basically stating that you don't know exactly what the pot diff between diff. objects are in this type of situation so the flow of current can be rather random due to so many variables.
The OP was given some basic strategies based on the most likely situation. Bottom line is you can't see these large pot differences until current flows. And the situation may change after current does flow, you may have a diff set of pot. differences between objects from one moment to the next. You don't wish to be the conductor that allows the pot diff to ground you big bags of conducting saltwater.
Even if roasted chicken smells good...
If you're on that much pot, you probably won't even notice that you've been electrocuted.
But you would smell good to others in the kitchen. So... its a trade off.
While I have nothing against a little friendly cannibalism, the idea of smelling good to my companions is a wee bit disconcerting...
If you have something metal in your hand you can toss it at the parts of the car and see what happens. If you get a spark then you better not touch it!
No. Taking this advice is a good way to get yourself dead.
If you have something metal in your hand and you toss it at parts of the car, most likely nothing will happen, whether or not the part is live with electricity.
A thrown metal object is electrically isolated, so it will not complete a circuit, thus would not show sparks. Thus, it tells you nothing about whether said part is live. You, on the other hand are not necessarily electrically isolated.
Aye. The best rule is to sit tight and not touch anything until the lines are disabled.
Plastic is not a good conductor of electricity - this doesn't mean it won't conduct electricity. You've probably noticed at some point plastic holding a static charge. Or have been shocked by a static build up from walking on carpet.
With ordinary electricity cables in your house plastic acts as a good insulator. But for high power transmission lines it does not.
A farmer near where I grew up. A storm knocked down a transmission line into one of his fields. He attempted to pick the fallen line up using a plastic bag to insulate himself - it didn't work out very well.
And the primary form of conduction is usually creepage. For example if the plastic bag is damp with condensation, or if the steering wheel is slick from the wife's handcream.
Porcelain insulators are essentially perfect insulators (10kV/mm), but their size and shape are designed to provide significant creepage distance along the surface which may become fouled with water, dirt, bird droppings etc. They are glazed with a smooth surface treatment to encourage shedding of water.
Electricity can tunnel through plastic pretty easily. If you think of a plastic bag like the dielectric in a capacitor - the electricity doesn't have far to go. If you picked up a transmission line with a plastic bag, the polymers in plastic will twist themselves into conductors (of course the plastic will melt and burn), but you'll probably have a pretty good conductor for a few milliseconds. And if they plastic melts to such an extent your hand is in direct contact with the line, you're in serious trouble.
Something like an ethernet cable - in the head, the plastic insulator covering the wires isn't broken - and they're not in direct connection with pins, but the distance is so short it's enough for the electricity to tunnel through.
And it's the same for things like light switches - the oxides that form over many metals are not good conductors(you could class them as insulators), but the layer is so thin the electricity just tunnels through it.
Someone I knew was doing work at an electric substation. One of the engineers was on a ladder, and he dropped a screwdriver. He reached out to grab it as it fell, and his arm touched two exposed points. From his hand to his elbow was carbonised instantaneously. The guy I knew said it smelled like a roast chicken. The engineer survived.
As the OP reading all the posts so far, I'm still confused. I have a few more questions:
1) So is it possible to touch nothing but plastic inside the car and still get lethally electrocuted?
2) If such a person does get lethally electrocuted in such a scenario, would death be instantaneous? If it's non-lethal, would it just burn his hand and not damage his neurons or his spinal cord?
3) Just how is it possible to leap out of a car without opening the door? Say you pull the doorwindow down, and then grab the window to assist yourself leaping out. Could you get electrocuted by touching the glass?
4) Could static from the downed transmission line or the Faraday cage-like car interfere/block cell phone radio signals?
5) What does it mean to say there could be a circuit between the car and the ground (asphalt)? Asphalt isn't a metal. If instead you're on a dirt road, then could a circuit still happen?
Yes.
Instantaneous death would be preferable.
Glass is a pretty conductor, you might have a chance.
So you wouldn't be able to call emergency services ...hmmmm...I wonder.
Yes the circuit could still happen. Maybe even more effective on mud road than asphalt.
High School The M paradox
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 20 ·
