Kinematics Problem: Cockroach Collision Calculation and Solution
The problem involves two cockroaches running towards each other with different accelerations, starting from a distance of 60 cm apart. The context is kinematics, focusing on motion with constant acceleration and the calculation of time until they collide.
  • Participants discuss unit conversion and the implications of the cockroaches' accelerations on their meeting point. There are attempts to calculate time and displacement for each cockroach, with some questioning the relevance of the maximum speed mentioned in the problem.
The discussion is ongoing, with participants exploring various interpretations of the problem setup. Some have provided calculations and reasoning, while others have pointed out assumptions that may not align with the problem statement. Guidance has been offered regarding the equations of motion, but no consensus on the solution has been reached.
There is a noted concern regarding the interpretation of the maximum speed of the cockroaches, as it is not explicitly stated that they reach this speed before colliding. The distance of 60 cm is a critical constraint in the calculations being discussed.
chonny
Please help me...I've been struggling for a long time over this following problem...
Some cockroaches can run as fast as 1.5 m/s. Suppose that two cockroaches are separated by a distance of 60 cm and that they begin to run toward each other at the same moment. Both insects have constant acceleration until they meet. The first cockroach has an acceleration of 0.20 m/s^2 in one direction and the second one has an acceleration of 0.12 m/s^2 in the opposite direction. How much time passes before the two insects bump into each other?
Please give me the answer and the steps leading to the answer as soon as possible...I am most grateful
If not...I will kill myself
first convert the cm to m so you use the same units. then use your logic. if two things are accelerating towards each other, then what is their acceleration?
after, just plug it into the formula
and on a side note, this belongs in homework help
Well...I'm stuck at this certain point...
Roach #1 has the A=.20 m/s^2
Well Time = Change in Velocity / Acceleration
1.5m/s dividedby .2m/s^2 = 7.5 s
Roach 1 would have a displacement of 5.625m from 1/2 * 1.5m/s * 7.5s
Roach #2 has the A=.12 m/s^2
1.5m/s dividedby .12m/s^2 = 12.55s
Roach 2 would then have a displacement of 9.375m from 1/2 * 1.5m/s * 12.55s
...now I'm stuck...how would I figure out where they would bump in that .6m distance and how much time passes when they bump
You appear to be assuming that the cockroaches accelerate to 1.5 m/s and that they meet when they reach that speed. That is not said anywhere in the problem. It simply says that "some cockroaches can run 1.5 m/s". Other than suggesting that the speed should not be more than that, it really isn't relevant to the problem.
If the first roach has acceleration 0.2 m/s^2, then its speed at any time, t, is 0.2 t m/s and the distance traveled (displacement) is 0.1 t^2 m.
If the second roach has acceleration .12 m/s^2, then its speed at any time, t, is 0.06 t m/s and the distance it traveled is 0.03 t^2 m.
At the time they meet they will, together, have covered the entire
60 cm= 0.6 m distance between them:
0.1 t^2+ 0.03 t^2= 0.6
Solve that for t to find when they meet and use that to determine the distance each has run to find where they meet.
Roach
